I just mean if we got source for any of the zvj roms a rom for optimus v zvj should be able to be hammered out without too much trouble.
Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
Using GitHub...
If someone copied everything used to build a Optimus S ZVJ GB Rom, and edited the newly copied source, with things to fix everything to function on V (mms, service, device type) and built from that, then it would all be fixed WHEN building a rom for OV ZVJ...
I still dont see the point of building a ROM for ZVJ OV when we already have everything working for OV "ZVD" (zv4, 5, 9).. and since my fix more or less fixes this (with exception of MMS(still questionably working, as reported by a few testers) and data on GB)
With just Root on the V, we have:
Optimus V Roms(Froyo, GB, ICS, JB(soon)) with just about everything working(unless told otherwise)
With Nitestalkr's method, we have:
Optimus S ZVD roms with everything working(unless told otherwise).
Optimus S ZVD roms with mostly everything working.(MMS has mixed reports for GB and ICS, Data has only 1 report of it working in GB(still unkown how it was accomplished), in JB mms isnt fixed in any Optimus build yet, in ICS and JB data IS working)
With Sammyz method, we have:
zvd roms with everything working, except mms won't work on the stock rom?
zvj roms with everything working, except mms won't work on the stock rom?
