01-17-2014 02:43 PM
470 ... 910111213 ...
tools
  1. ThatGuyLurkin's Avatar
    There's the Anycut way, and DFS way?
    07-26-2012 01:20 AM
  2. thewraith420's Avatar
    ?? Anycut is just to make a shortcut to a hidden menu and make it so the changes you make with dfs will actually stick.
    Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
    07-26-2012 02:09 AM
  3. sammyz's Avatar
    Here's anycut^^^
    Sent from my Optimus M
    07-26-2012 06:56 AM
  4. thewraith420's Avatar
    So has anyone else successfully made it over to fully functional zvj? Just wondering
    07-26-2012 08:00 AM
  5. sammyz's Avatar
    Phatninja55 has, or I know he made it to ZVD and got data working, not sure if he put ZVJ on it yet ....
    07-26-2012 08:08 AM
  6. andrewnelson23's Avatar
    I have a loooot of time today, so I'm highly considering switching over today, but I don't know yet. Does MMS work for you, or do you have a way of getting it?
    07-26-2012 08:50 AM
  7. sammyz's Avatar
    LMAO!
    Here's how to get mms working. You can probably take the mms config.xml add it to the mms.apk and have mms send working right away.
    This is for MMS^^
    I can't test it, I have MetroPCS
    07-26-2012 08:51 AM
  8. sammyz's Avatar
    That will only work with a ROM, not stock, so get a stock-like ROM and follow it.
    andrewnelson23 likes this.
    07-26-2012 08:54 AM
  9. sammyz's Avatar
    Updated OP, I have better data fixing instructions now, still needs work.
    07-26-2012 11:17 PM
  10. sammyz's Avatar
    OP finally finished
    Thanks to Phatninja for all the pics in his (old) unbrick guide and editing it for something more useful
    07-26-2012 11:43 PM
  11. nitestalkr's Avatar
    Updated my Guide to include your guide!!
    I like how we both always end up merging our work! xD
    @sammyz, how do you do the information windows in your guide??
    i wanna include a few in mine to make it look nicer
    sammyz likes this.
    07-27-2012 01:38 AM
  12. Phatninja55's Avatar
    I had working data/calls on zvj, but I never got mms working. I was to tired. Then I went back to zv5 for testing purposes. Havn't gone back yet.
    07-27-2012 01:44 AM
  13. Nate456's Avatar
    Well I'm done with this. Gave my little sister the OV after having everything zeroed out but I'm not going anywhere.
    07-27-2012 01:50 AM
  14. thewraith420's Avatar
    We just need someone to build or port a rom with the mms fix asadullah posted... It's a little out of my league... Good thing I don't really use mms much
    07-27-2012 02:17 AM
  15. Nate456's Avatar
    Where is this fix he posted? I forgot.
    Sent from my shole using Tapatalk 2
    07-27-2012 03:43 AM
  16. thewraith420's Avatar
    Post 256... Not far back Sammy reposted it.
    07-27-2012 04:04 AM
  17. Nate456's Avatar
    That is going be easy
    07-27-2012 04:08 AM
  18. thewraith420's Avatar
    I'm no coder
    07-27-2012 04:12 AM
  19. sammyz's Avatar
    [ INFO] words here [/INFO ]
    no spaces when typing the brackets and INFO....just like making things bold.
    But on tapatalk you will see the tags and not the info box.
    And ROFL soooo true.
    Sent from my Optimus V running Optimus S firmware on MetroPCS
    07-27-2012 07:17 AM
  20. sammyz's Avatar
    Updated OP with Step 0
    applies only to Windows 7/Vista users.
    07-27-2012 10:20 AM
  21. ThatGuyLurkin's Avatar
    I'm sure i can do the MMS thing. But not till Monday or Tuesday. Family vacation, Family Reunion.
    sellers86, thewraith420 and sammyz like this.
    07-27-2012 03:39 PM
  22. thewraith420's Avatar
    I've been trying... I have my build prop and apns edited to work but I'm having trouble with adding the cdmasmsdispacher added to classes.dex
    07-27-2012 08:46 PM
  23. ThatGuyLurkin's Avatar
    Ill take a look, but like always. No promises
    thewraith420 likes this.
    07-27-2012 10:10 PM
  24. thewraith420's Avatar
    Thanks! I didn't expect to see you today. I'm trying of course for hydroROM
    07-27-2012 10:22 PM
  25. andrewnelson23's Avatar
    Wraith you're still on the S firmware?
    07-27-2012 10:24 PM
