01-17-2014 02:43 PM
470 ... 1011121314 ...
tools
  1. thewraith420's Avatar
    Yeah... It's running great and I don't see the need to go back till I get bored again lol
    Edit: also i was playing with the S firmware before sammyz guide but never could stay because of no data
    Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
    07-27-2012 10:53 PM
  2. andrewnelson23's Avatar
    Are you able to run quattrimus, or do you have to downgrade to zvd via lgnpst to do that?
    07-27-2012 10:58 PM
  3. thewraith420's Avatar
    I would have to downgrade but there's an update.zip to do it.
    07-27-2012 11:04 PM
  4. andrewnelson23's Avatar
    really? well that's easy. but then you'd have to root, install custom recovery again and flash the rom. right?
    07-27-2012 11:05 PM
  5. thewraith420's Avatar
    Yep root and recovery again same rules apply as the zv9 update
    Edit flash stock recovery boot to it factory reset and install update.zip shouldn't break data either
    07-27-2012 11:08 PM
  6. thewraith420's Avatar
    New info! I just checked out the files in the zvd fix for jb and pulled thoes files from hydro rom and now I can run well....pretty much any from I want zv4 zv5 zv9 or zvd all from the zvj radio.
    EDIT: Heres the files. NOTE THIS IS NOT FLASHABLE.
    http://www.mediafire.com/?p45uy7mu5016lyd
    unzip them and put them in /system/libs/ of the rom you want to use on zvj and you'll have working data tested on cm7 and 9 OV roms.. This also means working MMS with the ZVJ Radio on the V. nitestalkr will be making it flashable
    Nate456 and mlson like this.
    07-28-2012 04:03 AM
  7. nitestalkr's Avatar
    Flashable should be up sometime mid-day of 7/28, its going to be the very first thing I do when I wake up!
    sent from my un-dead sammich.
    thewraith420 and mlson like this.
    07-28-2012 04:28 AM
  8. andrewnelson23's Avatar
    zv-4-5-9-d-to-zvj.zip
    MMS WORKS??!? :WHAT: how did that fix mms? Haha and won't we need to fix every rom for mms? Either way, you are a boss! I'm definitely switching over asap!
    07-28-2012 04:51 AM
  9. thewraith420's Avatar
    MMS works on vm roms on zvj with this not on the os roms
    07-28-2012 04:54 AM
  10. thewraith420's Avatar
    Yet.....
    07-28-2012 04:55 AM
  11. nitestalkr's Avatar
    Remember, its not yyet flashable.
    @Sammyz & thewairh420, if we can somehow manage to make installing ZVJ firmware easier (flashable zip, or update zip), then development for the Optimus V/S all basebands, could be taken place without worry of which phone, or baseband someone has. Which I'm sure devs would just LOVE!
    07-28-2012 04:56 AM
  12. andrewnelson23's Avatar
    Ohhh. Gotcha. But for that I'm assuming you could use that xda post that sammyz put in the other thread?
    07-28-2012 04:58 AM
  13. andrewnelson23's Avatar
    You should make two of these zips nitestalkr. One for s users and one for v users. Changing the build.prop identities and keys as well for each respective phone.
    07-28-2012 05:16 AM
  14. nitestalkr's Avatar
    That's on my morning todo list.
    Idk why, but all of this makes me feel like a little kid in a candy shop... basically just integrated rom development for both phones, and rendered all of those sayings about "LG Optimus S roms/firmware bricks Optimus V, and could never work." now false.
    07-28-2012 05:25 AM
  15. sammyz's Avatar
    <br />
    <br />
    Remember, its not yyet flashable.<br />
    @Sammyz & thewairh420, if we can somehow manage to make installing ZVJ firmware easier (flashable zip, or update zip), then development for the Optimus V/S all basebands, could be taken place without worry of which phone, or baseband someone has. Which I'm sure devs would just LOVE!<br />
    <br />
    I think I know of an easier faster way than LGNPST, I need to make it flash as a KDZ file and I know how to do this and no it won't flash by changing .cab to .kdz
    I got programs, I wont be home all day though will do it tonight ASAP.
    Sent from my Optimus V running Optimus S firmware on MetroPCS
    nitestalkr likes this.
    07-28-2012 07:07 AM
  16. asadullah's Avatar
    I'm wondering wouldn't it be easiest to do it via update.zip? Use the rooted deodexed rom as a base and then throw in the zvj radio or zvh. Have them use terminal or adb to flash the sprint recovery and flash away.
    07-28-2012 09:42 AM
  17. thewraith420's Avatar
    I've tried using the update.zip for zvd and h but there's too many traces of V firmware. The most I could get is voice sms and 1x data.
    07-28-2012 10:01 AM
  18. sammyz's Avatar
    Factory reset, then update.zip
    07-28-2012 01:55 PM
  19. thewraith420's Avatar
    I should have elaborated a little more. That was coming from VM670ZV4 firmware. I then ran optiauto to update to zvj directly but all I could get going was 1x for some reason. Since that I've re flashed the zvd bin and restored data all over again with no trouble. You were right the first time when you told me that's what had to be done. I'm not sure we'll ever have an easy way to zvj but at least now once it's working you can bring your favorite VM rom to zvj easy enough
    07-28-2012 03:49 PM
  20. sammyz's Avatar
    I figured that wouldn't work.
    Gonna work on this to flash as a KDZ, the ZVD cab, can someone test it please? Someone who is on ZV4/5/9 firware?
    07-28-2012 05:30 PM
  21. andrewnelson23's Avatar
    Sammyz, the op needs to be changed. you forgot to add in the last steps of the data fix. or the other thread by phatninja55 needs to have it in. that's the steps that include adding the meid@mdata.vmobl.com to the hdr an and the hdr an long data sections. Sorry, I would test for you, but I already went back to OS zvd.
    07-28-2012 07:05 PM
  22. andrewnelson23's Avatar
    Wraith, I can't seem to get data going. It's really annoying. I think I've done everything exactly according to your instructions. the problem is the hex's don't appear to stick now. I'll type them in and click write and then I'll read again and the hex's are cleared again.
    07-28-2012 07:14 PM
  23. thewraith420's Avatar
    Yeah..I know how ya feel. last night / this morning I went full zv4 to try using the update.zip files to get to rooted zvj but there was apparently too much vm670 firmware still there the best I could get was 1x data. So then I used e-mode to get to full zvd again and I'm once again on zvj with working data and running vm670 quatrimus.... yeah its been a busy day lol
    07-28-2012 07:16 PM
  24. sammyz's Avatar
    PM Phatninja55.
    07-28-2012 07:16 PM
  25. sammyz's Avatar
    ZVD quattrimus on ZVJ??? O.o
    07-28-2012 07:17 PM
