01-17-2014 03:43 PM
470 ... 1112131415 ...
tools
  1. thewraith420's Avatar
    You know... we should have a zvd to j patch for ppl that do this guide... with that there's no reason to go back to vm670 firmware as all the roms still work.
    sammyz likes this.
    07-28-2012 08:22 PM
  2. andrewnelson23's Avatar
    As in zvd roms to work on zvj? I thought that's what nitestalkr's latest project was... I need help Wraith. My hex's won't stick.
    nitestalkr likes this.
    07-28-2012 08:41 PM
  3. sammyz's Avatar
    I'll talk to nitestalkr
    07-28-2012 08:41 PM
  4. sammyz's Avatar
    Is it?
    07-28-2012 08:41 PM
  5. andrewnelson23's Avatar
    Is it?
    Yes. http://forums.androidcentral.com/lg-...able-zips.html
    sammyz and nitestalkr like this.
    07-28-2012 08:45 PM
  6. thewraith420's Avatar
    It is and I helped with it but when he made it flashable he added the OS keypad and other files. Not needed to make all VM rooms work on zvj radio
    07-28-2012 08:51 PM
  7. nitestalkr's Avatar
    One with the VM670 keypad will be here later today.
    The only reason I still include everything in the patch, is kind of there as an Easter egg, I'll later remove some of the things not needed, and include a scripted Easter egg.
    sent from my un-dead sammich.
    thewraith420 likes this.
    07-28-2012 09:00 PM
  8. sammyz's Avatar
    I just added link to the patch in the OP
    @thewraith420, I flashed my OV 3 times while in e-mode with the kdz flasher with my homemade ZV5 cab converted to kdz. Now it boots but no recovery mode at all O.o
    07-28-2012 09:03 PM
  9. nitestalkr's Avatar
    Try the good ole recovery install with terminal emulator
    07-28-2012 09:05 PM
  10. sammyz's Avatar
    No because I want to use the KDZ flasher for my unbrick guide instead of ole KP500....
    07-28-2012 09:06 PM
  11. nitestalkr's Avatar
    Well, do you have root? It sounds like you need to re-root and install a recovery.
    07-28-2012 09:15 PM
  12. thewraith420's Avatar
    Hmm did you read from lgnpst before going to dfs to make the edit
    07-28-2012 09:19 PM
  13. thewraith420's Avatar
    ...try again with lgnpst or kp500 to get recovery back?
    07-28-2012 09:22 PM
  14. andrewnelson23's Avatar
    Yep, I think that's what I was doing wrong. Got data working now!! WOOHOO! am I the only other person yet to do this besides Wraith? Now to root it, install custom recovery and restore back to my quattrimus and maybe try out hydro or something
    07-28-2012 09:44 PM
  15. thewraith420's Avatar
    I think its me you and Sammy who have done it.... I'd guess asadullah too but he Hasn't posted about it.
    Tapatalk'n it from my VM670 running LS670ZVJ Baseband
    07-28-2012 09:48 PM
  16. sammyz's Avatar
    Defeats the purpose
    also defeats the purpose.
    I went to ZVJ not rooted.....haven't gone to ZVJ rooted....so busy.
    I still never flashed a single jellybean ROM -_-
    07-28-2012 09:52 PM
  17. thewraith420's Avatar
    Defeats the purpose
    I haven't either dispite being able to.. I been enjoying hydro rom and jb is just too new right now
    07-28-2012 10:47 PM
  18. andrewnelson23's Avatar
    I'm having insane difficulties just trying to root the freaking thing on zvj. I keep getting a write: no space left on device message and then I check and still no root.
    07-29-2012 01:11 AM
  19. thewraith420's Avatar
    Did you run optiauto
    And at what step did you get that error
    Sent from my VM670 using Tapatalk 2
    07-29-2012 01:22 AM
  20. thewraith420's Avatar
    Come to think of it if your unrooted and on zvj your already to far and have to revert then run run gingerbreak and from the computer use optiauto to update and root zvj
    07-29-2012 01:33 AM
  21. andrewnelson23's Avatar
    no i used optiauto to root while I was on zvd and then used optiauto. it just wouldn't perform root/install su/recovery. I'm retrying the whole process.
    07-29-2012 01:37 AM
  22. andrewnelson23's Avatar
    Here's what I got on optiauto. Dang it, I don't think I can root it. any ideas??
    Code:
    Installing persistent root... write: No space left on device
    Done
    Waiting for filesystem to sync... Done
    Installing Recovery - Xionia CWMA... write: No space left on device
    [1]   Bus error               flash_image reco...
    Done
    Installing Misc - Clean... write: No space left on device
    [1]   Bus error               flash_image misc...
    Done
    07-29-2012 02:08 AM
  23. thewraith420's Avatar
    Code:
    Done
    Done
    Done
    If I can you can we just need to figure out what's different
    07-29-2012 02:12 AM
  24. andrewnelson23's Avatar
    Okay. The first time you rooted, did you root using opti or gingerbreak? I used opti. it gave me that error. then I used gingerbreak the second time. it rooted and everything but it couldn't update the binaries. I tried still using it and going to zvj from there but it didn't work. I don't know what that error means. Maybe I should redo everything(reflash the s firmware and start from scratch?) I've just been using the update.zip to go back to zvd everytime.
    07-29-2012 02:16 AM
  25. thewraith420's Avatar
    I rooted zvd with gingerbreak because the guide I used said I needed to start rooted
    07-29-2012 02:27 AM
