01-17-2014 03:43 PM
470 ... 1314151617 ...
tools
  1. thewraith420's Avatar
    Not too bad really...
    Edit: supposed to be a screen shot here.. Hmm
    Edit2: well anyways I ran speed test .net app and on zvj I get 267 ping 1094 down 797 up
    Tapatalk'n it from my VM670 running LS670ZVJ Dante Rom
    07-30-2012 07:04 PM
  2. andrewnelson23's Avatar
    How's that compare to zv5, zv4 or zv 9?
    07-30-2012 07:54 PM
  3. thewraith420's Avatar
    For me... It varies but this would be on the high end
    07-30-2012 07:57 PM
  4. andrewnelson23's Avatar
    this is what i do after writeing the .nvs file to zvd to get data back
    To Restore Data on LS670 Firmware:
    1: Install anycut.apk
    2: Run anycut and "create shortcut"-"Activity"-"LG HIDDEN DATA" and hit ok
    3: Return to desktop and open the shortcut
    4: go into CDG2 Data Settings and change PPP CARRIER from Sprint to Undetermined
    5: Hit back and the phone will reboot
    6: Open Qpst service programing and hit Load from file
    7: Select the .qcn file you saved durring prep
    8: Select write to phone and enter your spc
    9: The phone will reboot
    10: Open LGNPST and Select "Phone Setting" Enter your Spc hit ok then Read
    11: Close lgnpst and open DFS and enter your Spc and click SPC
    12: Click the Programing Tab then the Mobile IP TAB and click Read
    13: On the first Profile Uncheck the boxes next to Enter value in HEX for both AAA Shared Secret and HA Shared Secret
    14: Clear anything there and click write current profile settings
    15: go to profile 3 and Uncheck the Enter Value in HEX box for AAA Shared Secret and Copy the value
    16: Go To profile 2 and Paste that value into AAA Shared Secret box and Enter Vmug33k for HA shared Secret
    17: Hit Write current profile settings and switch to the data tab next to mobile ip and hit read
    18: under HDR AN and HDR AN Long you'll see YOURMEID@mdata.vmobl.com with PWD boxes under them
    19: Paste your AAA Key that you copied earlier into both pwd boxes and hit write
    Reboot Phone and you will have Data
    worked FLAWLESSLY. I think it was the .qcn thing.
    07-31-2012 12:46 PM
  5. sammyz's Avatar
    I didn't want to add a 3rd program -_-
    Sent from my Optimus M
    07-31-2012 01:02 PM
  6. andrewnelson23's Avatar
    Okay, so new problem. After moving up to zvj, everytime I try to root it with the optiauto tool, I get these errors when attempting the exploit.
    Code:
    Installing persistent root... write: No space left on device
    Done
    Waiting for filesystem to sync... Done
    Installing Recovery - Xionia CWMA... write: No space left on device
    Done
    Installing Misc - Clean... write: No space left on device
    Done
    ---- END LOG ----
    I followed the directions to a T, and I'm not sure what the problem is.
    07-31-2012 01:10 PM
  7. sammyz's Avatar
    Code:
    Done
    Done
    Done
    ---- END LOG ----
    Someone who owns an optimus s got the same errors, i'm not sure what they did though...post in the thread saying you are running optimus s firmware.
    try factory resetting first.
    07-31-2012 01:13 PM
  8. andrewnelson23's Avatar
    I'm becoming a pro at putting the zvd firmware on my V and getting everything working. Just did it for the fourth time this morning. took 15 minutes for the entire process. win. Now if I could just successfully get zvj rooted, I'd be happy.
    07-31-2012 01:30 PM
  9. andrewnelson23's Avatar
    I tried factory resetting it and wiping cache, but that didn't work. I don't know why it keeps saying that. It's very frustrating. AND, I have better service while on zvj. So I really want to get this rooted.
    07-31-2012 02:28 PM
  10. thewraith420's Avatar
    Your not missing the part where you run update.zip again and it fails (expected) are you? It says out of space... Is your sdcard full?
    07-31-2012 03:46 PM
  11. andrewnelson23's Avatar
    it still had 3.5 gigs left on it. No, I got to that part, where it said error 7 installation aborted and then tried the root exploit and that's what popped up on optiauto. I'm now just on rooted zvd, gonna restore my backup of quattrimus. that way it'll be easier to get to zvj if we can ever figure out how to root it for me.
    07-31-2012 03:51 PM
  12. thewraith420's Avatar
    As far as I can remember the install update.zip fail was part of the root exploit...
    07-31-2012 04:05 PM
  13. thewraith420's Avatar
    I'm tempted to go to zvd and run through the process again. Btw... Are you reverting using lgnpst every time cause there's an easier way back to zvd
    07-31-2012 04:07 PM
  14. andrewnelson23's Avatar
    I mean after clicking install update.zip on my phone and getting that error, you're supposed to type C in the optiauto-that's supposed to get you to root/custum recovery, etc.
    07-31-2012 04:09 PM
  15. andrewnelson23's Avatar
    Since I'm now on the ZVD radio on a backup of quattrimus from when I was on ZV9, should mms work??
    07-31-2012 04:57 PM
  16. thewraith420's Avatar
    Yes. It did for me from zvj too. The mms is a rom issue S roms just weren't made for us V users... We've come this far though I'm sure it'll get worked out.
    07-31-2012 05:28 PM
  17. andrewnelson23's Avatar
    Hmm. Couldnt get it to work on quattrimus,but youre right,it is a rom thing. I went to harmonia backup and mms worked!
    07-31-2012 06:57 PM
  18. sammyz's Avatar
    Have to use optimus v quattrimus....
    07-31-2012 06:59 PM
  19. andrewnelson23's Avatar
    its by far my favorite daily rom and it was optimus v quattrimus. It was a backup.
    07-31-2012 07:16 PM
  20. thewraith420's Avatar
    Try a clean install? I know it works on iho for me
    07-31-2012 08:25 PM
  21. thewraith420's Avatar
    Make any progress with optiauto yet andrew? I just reverted to zvd to reroot and update to rooted zvj again and it all went smooth including having optiauto root zvd for me
    08-01-2012 03:48 PM
  22. andrewnelson23's Avatar
    Haven't had time I might try tonight. I'm going to wipe my sdcard and hope that works. I'll also do the zip of optiauto instead of the self extractor.
    Optiauto rooted zvd fine. It wouldn't root zvj after installing the zvj. .
    08-01-2012 04:15 PM
  23. thewraith420's Avatar
    I forgot about that! I've been using the zip
    08-01-2012 04:27 PM
  24. thewraith420's Avatar
    Also I think there's a manual root method I've never tried
    08-01-2012 04:28 PM
  25. andrewnelson23's Avatar
    I love how there's like three people in this whole thread. Wonder if others even read it!
    nitestalkr likes this.
    08-01-2012 05:27 PM
