Ohhhh. Okay I see. Well Cammy if you REALLY want that, you can follow Sammyz guide to get it working.
I wouldn't do that yet, I have to edit OP and I haven't been hone ALL day.
Sent from my Optimus M
I thought they were pretty straightforward. Here's the DFS dl. You want 4.0.0.4. Unrar, and install.
His method basically consisted of this:
do your method of recovery nvs.
then install anycut.
Use anycut to navigate to create a shortcut to cdg2 data settings.
open that shortcut and select undefined rather than sprint.
Use dfs
to use dfs, have your phone on and plugged in. there'll be a box with 6 0's in it. to the left of it is spc. replace the 0's with your spc and then click spc. dfs will read your phone. immediately underneath where you entered the spc, there is a programming tab. click that. then click the mobile ip tab. on the left hand side at the bottom, click READ. select the first profile. Edit the first box to be MEID@mdata.vmobl.com. (replace MEID with your personal MEID. Can be found underneath battery if you don't know it.) All of the addresses should be 0.0.0.0. Now enter your HEX's. make sure to uncheck the boxes before you enter anything in them.
Second profile should be set up exactly the same way. the third profile should be set up the exact same way as well, but make sure to swich the <mdata> part with 'prov'.
Now click write! after this, let it reboot and on the left hand side, click read again to make sure the mobile ip profiles stuck.
Now click the data tab which is right next to the mobile ip tab.
In the HDR AN and HDR AN LONG sections, you should see MEID@mdata.vmobl.com. underneath those, you should see pwd boxes. paste your AAA keys in there.
Then reboot and you should have data.
Why didn't they restore for me? and what's the point in putting up my fix for data if lgnpst backs up and restores the data?
Actually you don't lose them. LGNPST actually does backup and restore them...ThatGuyLurkin "showed" me. I was helping him with teamviewer...
There's the Anycut way, and DFS way?
So has anyone else successfully made it over to fully functional zvj? Just wondering
Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
LMAO!
Here's how to get mms working. You can probably take the mms config.xml add it to the mms.apk and have mms send working right away.
