I've encountered these problems:
- Lock ups now and then
- Data goes out and on( this only happens like twice a day to me for 3 seconds )
I'll test hydro tomorrow, all day.
sent from my un-dead sammich.
Been testing MMS now that I'm home. It seems that if I mess with Framework.jar, it goes straight to having Phone spam Force Close. I'm gonna see if I can find a way around.
I also get something about update device has force closed. I don't know what that's about. :-\
Stockness makes everything complicated.... All the files are different than CM7.
Data works perfect for me, although flashing the zip doesn't give me data. I have to put then in manually and use solid explorer our anything with root. Does the zip give you data?
Ok. So I changed files that you've included into the zip, and this zip seemed to work for me perfectly.
I used the libs from your old patch that wouldn't flash right. If I added the other _exp.so file, things didn't work right. So, credits to you ofc. I just fixed the zip.
I added them to a zip and flashed, and then I had data right out the box.
Working on MMS now. I was talking with Cammy and suddenly got 3 different ideas.
I also noticed that there's a CDMASMSDispatcher or whatever in the CDMA folder, and not in the Telephony folder. (If you know what I'm talking about)
If you don't, I could teach you and maybe we can help each other out?
GingerBread V is based on Google's code, so I'm wondering what if we decompile the Framework.jar from that rom and use CDMA_______.smali stuff to try to fix MMS. ?
Not entirely. The second I mess with CDMA dispatcher, I get phone force close.
Modding the framework.jar from Hydro Rom, or Dante Rom, or even stock for that matter, wouldn't cause any problems that I'm aware of.
Each one of them is based on Stock ZVJ using the same Framework.jar. I'm gonna mess with the Stock ZVJ rom and see if I get Phone Force Close.
