Here is updated easy to understand unbrick directions:
00. Download and install LG USB Drivers for the LG VM670
01. Install MSXML 4.0 SP3 Parser (msxml.msi)
02. Your computer needs to be connected to the internet.
03. Connect phone in emergency mode (Phone off> Volume Down + Back key + plug in USB)
04. Run KDZ_FW_UPD.exe
05. In type, choose 3GQCT
06. In Phonemode, choose EMERGENCY
07. Choose the ZV5.kdz
08. Click Launch software update
09. Wait for the error to come up (this might happen a few times in a row just keep repeating steps
10, 11, and 12)
10. Press OK
11. Unplug phone, pull battery, press power button for 30 sec. then reinsert battery and get back into emergency mode.
12. Click Launch software update
When everything is working correctly you should get a readout that pops up that shows a
scrolling text that eventually will display:
wParam:7, IParam=00
then:
wParam:7, IParam=01
and so on and so on until you get to
wParam:7, IParam=100
(in the middle of all this you will ocasionally get a dll message error, this is normal), then
you will get:
wParam:8, IParam=00
It should now go into battery charge mode, or recovery mode, or boot into the phone.
13. Enjoy
Notes:
01. If it stops before wParam:8, IParam=00 or it hangs in the bootanimation, and you have no recovery, get into the fastboot screen (same
way you get into the recovery, but with no recovery it will automatically go to the fastboot
screen).
Plug the phone into the computer and open a terminal in C:/ SDK/ folder the fastboot.exe is in (Windows it's the tools folder/Linux it's the platform-tools folder) that you
should already have on your C: drive (If no SDK folder let me know, I have one you can download).
Then type in this code:
fastboot erase recovery
fastboot erase boot
fastboot erase system
fastboot erase userdata
fastboot erase cache
Pull battery, get into the E-mode and start the KDZ utility over.
02. If it boots into the recovery just select the "wipe data/factory reset" option, unplug the phone
from the computer and then select the "reboot system now" option.
03. If it goes to battery charge mode just unplug from computer and push the power button.
04. On the first boot up it might takes as long as 10 minutes to fully boot into the lockscreen.
Upgrade/Downgrade/Return to stock directions:
00. Install Drivers, Reboot
02. Connect phone in recovery mode (Phone off> Volume Down + Home key)(This will not work with
certain recoveries so try the Xionia or the VM670NH recovery's first)
03. Run KDZ_FW_UPD.exe
04. Select the ZV5.kdz
06. In Phonemode, choose DIAG
07. Click Launch software update
08. Enjoy
Made by Sammyz: Updated by AndyOpie150 on Wed/02/October/2013
