- Forum
- LG Android Phones
- More LG Phones
- LG Optimus Series
- Virgin Mobile Optimus V
- Optimus V Rooting, ROMs, and Hacks
Model Dll Msg Not Found(20, 570)
- I have run into quite an issue. Very new one to me and I'm at a bit of a loss. I went to partition my phones sd card and some where along the way must of screwed something up. (I bought a new sd card to test that) It would only load the LG Logo screen and stick on that one screen. Recovery is not an option as it will not load. ADB is not an option because even though the LG Logo screen loads, regular drivers don't install when connected to USB like they normally would.
So I left my phone for awhile as I had gotten busy and didn't have time. Uncharged that is. I went to plug it in to charge and it still stuck on the lg logo screen. The difference this time was the power button wasn't working. New battery tested, still nothing. So then I put the phone into emergency mode while pressing the required buttons and connecting the usb all at the exact same time. So obviously the power button works but the phone won't turn on unless connected to a power source. Even with a new battery in.
o I utilized every method out there to see if I could somehow get the phone working via emergency mode. The most promising two methods that worked were KDZ and KP500 methods. The closest I can get is doing the KP500 method. However; even that seems to fail.
Everything (analysis, download) work up until update. The progress gets to 4% and then the phone does it's emergency mode cycle where it connects to usb/disconnects/reconnects/etc. Leaving the progress bar at 4% - or right around this point ---> 14:40:20 : Model Dll Msg Not Found(20, 570)
I was running the newest xionia clockwork mod, with the newest IHO backside rom (green machine theme) on a lg optimus v vm670 at the time of the issue. I'm doing all of this on a 32 bit windows 7 starter acer aspire one netbook with admin privileges.
14:39:07 : [C:\LGMobileUpgrade] 丮 õ
14:39:07 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
14:39:07 : Start Date : 2012-08-02 14:39:07
14:39:07 : -------- Buyer Test mode ---------
14:39:07 : [C:\ProgramData\LGMOBILEAX\Phone] 丮 õ
14:39:07 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
14:39:07 : *****CheckOS Start********
14:39:07 : Microsoft_Windows_Vista Home Edition_
14:39:07 : *****CheckPCSyncPrograms Start*****
14:39:08 : PCSyncPrograms Not Found
14:39:08 : SetEmerModeAT()
14:39:08 : _IsConnectedPhone Call
14:39:08 : _IsConnectedPhone(0)
14:39:08 : 0 - NotConnected.
14:39:08 : 1 - Normal connect success
14:39:08 : 2 - Emergency connect success
14:39:31 : Checking the connection with the cell phone...
14:39:31 : dwWaitResetTime(40000 ms)
14:39:32 : _IsConnectedPhone Call
14:39:39 : _IsConnectedPhone(2)
14:39:39 : 0 - NotConnected.
14:39:39 : 1 - Normal connect success
14:39:39 : 2 - Emergency connect success
14:39:39 : Phone Mode(2)
14:39:39 : *****GetPhoneType Start*****
14:39:41 : Phone Type : CDMA
14:39:41 : *****Start GetPreviousStep*****
14:39:41 : _GetPreviousStep(dwStep:0xffff)
14:39:41 : *****GetPhoneBinaryVersion Start*****
14:39:41 : CSE mode -> Version Replace
14:39:41 : *****Get ESN / IMEI / MEID Start*****
14:39:54 : *****GetPhoneNumber Start*****
14:39:57 : Phone Number : 00000000000
14:39:57 : ˻ ĶŸ - ESN_IMEI : 00000000000, Model :
14:40:00 : _GetAuthMark : wAuthMark(19933)
14:40:00 : Wait 3Sec
14:40:05 : _SetAuthMark Ok : wAuthMark(19933), PhoneMode(2)
14:40:05 : *****CheckPCSyncPrograms Start*****
14:40:06 : PCSyncPrograms Not Found
14:40:07 : CLGMobileHttp Class Ҹ.
14:40:07 : CLGMobileHttp Class Ҹ...
14:40:07 : ****************CheckAndDownload****************** **
14:40:07 : ******Extract Start C:\KP500-Utils-EN\ZV5.cab*****
14:40:07 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
14:40:15 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\ZV5.wdb\n
14:40:15 : WDB(or DZ) FullPath(C:\ProgramData\LGMOBILEAX\Phone\\ZV5.wdb)
14:40:16 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LS670_W_0_0_2_0.d ll\n
14:40:16 : Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\\LS670_W_ 0_0_2_0.dll)
14:40:16 : NNNNN WDB FullPath(C:\ProgramData\LGMOBILEAX\Phone\ZV5.wdb)
14:40:16 : NNNNN Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\LS670_W_0 _0_2_0.dll)
14:40:16 : Extract End C:\KP500-Utils-EN\ZV5.cab
14:40:16 : *****WorkModelDLL Start*****
14:40:17 : strPhoneBinaryPath(C:\ProgramData\LGMOBILEAX\Phone \ZV5.wdb)
14:40:17 : strModuleDir(C:\ProgramData\LGMOBILEAX\Phone\)
14:40:17 : strModelDLLPath(C:\ProgramData\LGMOBILEAX\Phone\LS 670_W_0_0_2_0.dll)
14:40:17 : m_nPhoneMode(2)
14:40:17 : Phone mode 1 = Normal
14:40:17 : Phone mode 2 = Emergency
14:40:17 : Phone mode 4 = CSE
14:40:17 : _DetachDLL Call
14:40:17 : _DetachDLL Call End
14:40:17 : Call fn_StartUpgrade
14:40:17 : ### Start Upgrade - CDMA ###
14:40:17 : ********* CDMA Model.dll input Parameter *************
14:40:17 : MODEL_EVENT : 32769
14:40:17 : PhoneBinaryPath : C:\ProgramData\LGMOBILEAX\Phone\ZV5.wdb
14:40:17 : ModuleDir : C:\ProgramData\LGMOBILEAX\Phone\
14:40:17 : BootWaitTime : 49500
14:40:17 : UsbHighSpeed : FALSE
14:40:17 : PhoneMode : 2
14:40:17 : NewPhoneBinVersion : ZV5
14:40:17 : ClearSI : FALSE
14:40:17 : AuthMark : 19933
14:40:17 : ********* CDMA Model.dll input Parameter End*************
14:40:19 : wParam : 20, lParam = 570
14:40:19 : MODEL DLL Event : (20, 570)
Anyone with any suggestions or ideas? Would be nice to unbrick this phone someday since I've reverted back to a measly flip phone in the meantime.08-02-2012 04:29 PMLike 0 -
Sent from my LS670 using Android Central Forums08-02-2012 06:04 PMLike 0
- Forum
- LG Android Phones
- More LG Phones
- LG Optimus Series
« How many custom ROMs are out there for the newer OV?
Porting Optimus S ZVJ ROMs to Optimus V ZVJ »
