1. Jacobvm670's Avatar
    whats the smoothest rom for optimus v with long battery life??
    08-02-2012 08:16 PM
  2. EarthnFire78's Avatar
    This is what I think
    1. Resurrected Bumblebee
    2. Harmonia 1.87
    3. Harmonia 2.+
    4. I would say it's a tie between Migage and OM-Mandylion.
    5. Backside and Magpie
    6. BobzHome
    The ICS roms have about the same battery life as stock
    topdawg661 likes this.
    08-02-2012 08:38 PM
  3. Anonymo's Avatar
    Probably MiRage
    08-02-2012 08:40 PM
  4. Jacobvm670's Avatar
    Is there a newer rom that is ics
    08-02-2012 09:08 PM
  5. kboone13's Avatar
    Harmonia 2.09 definitely. The ICS roms are still being worked on, so I wouldn't use them as a daily just yet. But if you want the look of ICS, you can always apply a theme!
    08-03-2012 12:55 AM
  6. r00t's Avatar
    Mirage's with the governor settings he describes.
    08-03-2012 01:03 AM
  7. Tacular Z's Avatar
    Harmonia 1.9 for sure! Mirage, G-T-R, and Gingersnap are all up there for sure though!
    08-03-2012 01:11 AM
  8. Jacobvm670's Avatar
    Link to mirage and Gingersnap???
    08-03-2012 01:41 AM
  9. Jacobvm670's Avatar
    And I want mms fixed for picture and video sending I have bobzhome and they don't work
    08-03-2012 01:42 AM
  10. Tacular Z's Avatar
    MMS works on almost every ROM except for Ice Cream Sandwich.
    Mirage link: http://forums.androidcentral.com/opt...cm7-2-iho.html
    Gingersnap link: http://forums.androidcentral.com/opt...ll-update.html
    If you're really looking for maximum battery life, download Battery Defender off the market, and use interactive governor set 122 MHz as minimum and whatever you're max overclock is, I'll just assume 806. And there you go.
    08-03-2012 01:54 AM
  11. cole2kb's Avatar
    MMS works on Quattrimus just fine...pretty sure it works on Bobz ICS as well.
    08-03-2012 03:27 AM
  12. dbacon84's Avatar
    I am loving Gingersnap right now. I've used both Harmonia & Mirage and would rank them in my top 3. I have had the least # of fc's w/ Gingersnap and it is smooth and has great battery life (all 3 are pretty good on battery if you have a good OC setup).
    08-03-2012 06:59 AM
  13. A-android-B's Avatar
    The 7/27 build of ics from Bobz is awesome for battery life, but please don't take my word for it just back up and flash. It only takes a minute to nand back. As for juice defender. Why would some one run another app constantly to try and improve battery life? Seems to defeat the point in my eyes.
    08-03-2012 05:28 PM
  14. A-android-B's Avatar
    And low clock speeds aren't exactly proportioned to battery life as one would think.
    08-03-2012 05:30 PM
