1. QuinnSF's Avatar
    I keep getting the above error when I try to download or update apps from the Play store. I have plenty of space on my SD and internal memory. What do I do to fix it? I've tried multiple ROMS, clearing all the cache stuff (I think, I might not be clearing em properly as I am new to this) everytime.
    I read that I should transfer my dalvik cache to my SD card so I can properly delete the cache but I have no idea how to do this, are there other ways to fixing this problem?
    Is it Titanium Back-up's fault?
    Also, I've tried Quattrimus ICS rom and it looks awesome but how do I get the Play store on that rom?
    Lastly, what's a kernel for?
    On all the roms I've tried, I can't seem to be able to connect my phone to my computer, is it suppose to be like that?
    danop likes this.
    08-04-2012 11:52 PM
  2. ThatGuyLurkin's Avatar
    To connect your phone to PC, download this:
    http://www.lg-phones.org/wp-content/
    uploads/LG-Optimus-V.zip
    A kernel is what makes the phone run. Without, your phone would be useless.
    For Quattrimus, you have to flash these after flashing the rom, that'll get you your market.
    www.mediafire.com/?per5263a0j7rs6h
    SD Card space doesn't affect the market. How much internal space do you have left? And what rom are you on?
    08-05-2012 01:55 AM
  3. QuinnSF's Avatar
    gapps-ics-20120429-BobZ.zip
    How come I didn't have to download it to connect to my computer when I was running stock rom? I just had to press that button on my phone.
    Do I do the same thing I do when flashing those extra things? (As in clearing dalvik cache, etc... clearing everything except sd card?)
    Right now I have 44mb of internal space. I am using Harmonia 1.9, I've used Harmonia 2.8 (or something close to that) along with two other cyanogen copies that I don't remember the name of. Either way, they all ended up having the "insufficient memory" error once I Titanium Backed-up.
    08-06-2012 12:35 AM
  4. kobequintana's Avatar
    If you have a SD ext u need to make it bigger
    08-06-2012 12:57 AM
  5. QuinnSF's Avatar
    Do you mean my SD card size? I have 5.5gb free.
    08-06-2012 01:13 PM
  6. QuinnSF's Avatar
    Bump, how do I flash gapps after I flash a rom? do I clear the exact same things?
    08-07-2012 03:13 AM
  7. cole2kb's Avatar
    You don't need to clear anything, usually. If you've already booted into your new ROM, clear cache and dalvik cache, flash GApps, reboot. If you're flashing a new ROM, clear everything, flash ROM, flash GApps, reboot.
    QuinnSF likes this.
    08-07-2012 02:14 PM
  8. QuinnSF's Avatar
    Thank you!
    Can you tell me how to fix my "insufficient memory" error?
    08-07-2012 03:41 PM
