12-31-2014 11:37 AM
35 12
tools
  1. metal321's Avatar
    I am trying to go back to the factory ROM because I am getting a setup screen that connects me to Sprint. I have a VM phone. I know for a fact that I installed a VM ROM, so I have no idea why it is doing this. And the reason I don't like COT is because it is totally different from the standard recovery. It is much easier to find explanations online of how to do things with the standard recovery than it is with this COT recovery.
    08-11-2012 05:45 AM
  2. metal321's Avatar
    When I try to install a different recovery the information on the screen races by and you can't read any of it and then COT just goes back to the previous menu. It doesn't display any of the information on the screen like the other recoveries so you have no idea what happened. I don't understand what is so great about this recovery.
    08-11-2012 07:46 AM
  3. andrewnelson23's Avatar
    Again. Use flash image gui to get a new recovery. And that makes absolutely 0 sense. Out of the approximately thousands of times quattrimus has been flashed, you are the first person with this problem. You must be doing something wrong.
    08-11-2012 08:49 AM
  4. sammyz's Avatar
    I think he flashed the Optimus S version.
    Sent from my LG-LW690 using Tapatalk 2
    08-11-2012 09:09 AM
  5. Blueraydude's Avatar
    Hey, I'm having the same exact problem as OP was, it appears that your link is broken, does anybody have the file?
    Thanks.
    08-14-2012 11:13 PM
  6. BlairFam07's Avatar
    Here is the newest zip http://www.teamhydro.info/downloads/...670-signed.zip install for COT only the touch buttons dont work right now so use the vol. buttons and cam button. also show respect to OP . . http://forums.androidcentral.com/opt...13-2012-a.html
    08-16-2012 10:42 AM
  7. Joseph Petrides's Avatar
    Does anyone still have the zip file mentioned above? I know this is 2 years later, but it looks like that file can no longer be downloaded.
    12-30-2014 03:57 PM
  8. Joseph Petrides's Avatar
    Hi Andrew - do you still have this zip file you linked to? I'm trying to repurpose my optimus v as a mp3 player and I made the same mistake as the poster here.
    12-30-2014 03:59 PM
  9. bigsupersquid's Avatar
    cot recovery seems to be all dead links.
    xionia will break your bootloop too.
    http://forums.androidcentral.com/att...ery-signed.zip
    just don't use it to flash post gingerbread roms. break your bootloop, reboot once. flash mirage for your mp3 player, it's best and most stable.
    tli likes this.
    12-31-2014 07:16 AM
  10. tli's Avatar
    This is the latest version of COT that I found. The ZIP installer contains COT variations for the LS670, MS690 and VM670. FYI:
    COT-Installer-Optimus-v2.1-signed.zip
    MD5: 4957626dc03b25b7ba932c5e250ac073
    Date: Friday, March 29, 2013, 5:13:56 PM
    Size: 17.7 MB (18,643,148 bytes)
    bigsupersquid likes this.
    12-31-2014 11:37 AM
35 12
