1. suicidalerik's Avatar
    need a button fix for the ov. flashed a optimus s rom and now i need the buttons to get fix. anyone know where i can get a flashable zip
    08-12-2012 11:05 AM
  2. jonny5449's Avatar
    Use nitestalkrs patch
    Sent from my LG-LS670 using Tapatalk 2
    08-12-2012 11:14 AM
  3. suicidalerik's Avatar
    where can i find it
    08-12-2012 11:19 AM
  4. jonny5449's Avatar
    http://forums.androidcentral.com/sho...d.php?t=194211
    08-12-2012 11:25 AM
  5. suicidalerik's Avatar
    Oh i saw that but is there any flashable zip for only the button swapping
    08-12-2012 11:27 AM
  6. jonny5449's Avatar
    Use the file in the zip in the usr folder
    Thunderc keypad
    Replace the one in the rom with the one in the zip
    Give permission
    Reboot
    suicidalerik likes this.
    08-12-2012 11:37 AM
  7. suicidalerik's Avatar
    thanks that worked
    08-12-2012 11:40 AM
  8. jonny5449's Avatar
    thanks that worked
    No problem glad to help
    08-12-2012 11:50 AM
  9. Phatninja55's Avatar
    Mms wont work just so you know. S roms don't have working mms on v's
    Sent from my VM670 with LS670ZVJ using Tapatalk 2.
    sellers86 likes this.
    08-12-2012 03:02 PM
