1. adamhos's Avatar
    Awesome program
    Definitely try it out if you haven't yet!
    Gingersnap rom
    08-15-2012 07:56 AM
  2. adamhos's Avatar
    The title was supposed to be UOT kitchen!!
    08-15-2012 07:58 AM
  3. Phatninja55's Avatar
    Nice. You could keep the title because people will think you are talking about your theme.
    adamhos likes this.
    08-15-2012 10:53 AM
  4. adamhos's Avatar
    That's right, its the HOT theme!
    08-15-2012 11:10 AM
  5. anthonycr's Avatar
    Spell kitchen correctly though
    In case you didn't know how, you can change the title by editing the first post and then clicking advanced editor and you can fix it if you want.
    adamhos likes this.
    08-15-2012 11:55 AM
  6. adamhos's Avatar
    08-15-2012 02:17 PM
  7. irish-68's Avatar
    I'm on Gingersnap too. Played around with the UOT kitchen the other day. Was able to change the 3G/1X icons (which are kinda ugly) but the battery ones wouldn't take. Also tried it with the center clock fix script, but it wouldn't work. My next trick was to add some custom-made PNG icons (38x19px, and pretty snazzy looking) to the SystemUI apk (though the dimensions were different than the ones I was replacing, but with the same exact file names). Result was that the status bar did not show up on top but some garbage showed up on the bottom of the screen. Still tinkering with mine, and may do another kitchen project. Also may decompile the apk and take a look at the XML script. I could possibly change a few things there. Still playing around with it.
    08-15-2012 03:28 PM
  8. anthonycr's Avatar
    You should play around with my theme template for cm. Thats a lot of fun
    08-15-2012 03:55 PM
  9. adamhos's Avatar
    I was having issues at first, but I clicked the amend option, and uploaded framework, and systemui straight from my phone and that's when everything started to 'click'. I'm having a blast with my 'new' v!
    08-15-2012 03:59 PM
  10. adamhos's Avatar
    where can i find the theme template?
    thanks
    Encerspay45 likes this.
    08-15-2012 06:14 PM
  11. anthonycr's Avatar
    thanks
    I've posted it in the android theme section of xda (it may be hard to find) and over at http://forum.digitalhouseoftreats.co...opic.php?t=121. I have a bunch of other helpful tutorials to help you if that isn't enough. I should really put a link in my sig...
    clodfelterac and adamhos like this.
    08-15-2012 07:25 PM
  12. irish-68's Avatar
    I tried the amend option and my phone wouldn't support it (using the Gingersnap ROM). Told me to use edify instead.
    I'm still throwing stuff against the wall to see what sticks. Trying to incorporate a clock-centering script. Still working on it.
    08-16-2012 06:23 PM
  13. inceyet's Avatar
    Awesome program
    Gingersnap rom
    Sorry cant dl ur a buckeye fan lol nice work though but still the buckeyes
    08-16-2012 06:44 PM
  14. adamhos's Avatar
    I bleed scarlet and gray
    08-16-2012 08:55 PM
  15. inceyet's Avatar
    Lol that's what's up I bleed burgandy and gold GO TROJANS!!!!!
    08-17-2012 01:36 AM
  16. adamhos's Avatar
    I like this one!
    08-18-2012 07:54 AM
