1. suicidalerik's Avatar
    can someone make this completly work on the optimus v including mms, and everything nessesery
    http://forums.androidcentral.com/lg-...3d-7-24-a.html
    08-16-2012 12:46 AM
  2. ThatGuyLurkin's Avatar
    Flash rom, gapps(if needed), and Nitestalkr's ZVJ to ZVD patch.
    08-16-2012 03:06 AM
  3. suicidalerik's Avatar
    Would that fix mms
    08-17-2012 05:46 AM
  4. inceyet's Avatar
    You know there is already a joyos for the ov bornagainpenguin took over that rom
    http://forums.androidcentral.com/showthread.php?t=179378
    [ROM][PORT] Joyfully Optimus - Ios Gingerbread Rom!!!
    08-17-2012 12:13 PM
