[ROM][WIP]CM10.0.0-RC0-BobZ
BobZhome
296
627
Jellybean(Android 4.1.2)
Builder: BobZhome
Current Version: CM10.0.0-RC0-VM670-BobZhome (11-3-2012)
Description: Well, let's be honest. Unless you're living under a rock, you probably know what Android 4.1.1 (Jellybean) is. Furthermore, you should know what the CyanogenMod project is. However, if a rock is really your home and you'd like to learn more, please visit their site: CyanogenMod | Android Community Rom based on Ice Cream Sandwich
==== '''People worked with/owe thanks to:''' ====
CyanogenMOD - Do I need to state why we owe thanks to this guys?
IHO Team - Starting the IHO project
LGICS Team - For the great support they give to a bunch of LG devices
==== '''What is not working?''' ====
  • Data randomly disconnects
  • Time Lag
  • Camcorder
  • USB Tethering
  • Wi-Fi Tethering
Maybe more, I haven't fully tested...but I'm sure you will let me know :-*
==== '''Changelog''' ====
11-3-12:
  1. Sync'd with CM10: Now at Android 4.1.2
  2. Fixed: Notification Blur
  3. Fixed: USB mass storage
  4. Tweaked: Button Lights(they behave nicely now)
  5. NOTE: Also new custom Gapps below
9-15-12:
  1. Sync'd with CM10
  2. Fixed: Brightness
  3. Fixed: Proximity Sensor
  4. Fixed: Baseband Info
  5. Added: Asserts to make it easier for the LS-670 friends to flash
  6. Changed: Script - Now using A2SD++ thanks to Croniccorey over on XDA(see Q & A below for more info)
8-31-12:
  1. Sync'd with CM10
  2. Changed: Boot Animation(using official new smaller version)
  3. Fixed: RIL(data no longer disconnects)
  4. Tweaked: Smaller Keyboard with only English and Spanish
  5. Moved: Dalvik-Cache back to the Data partition(see Q & A below for more info)
  6. Kernel 4.2: Tweaked to help with the distorted view when using Camera
  7. Added: New Custom Gapps below(also see Q & A for more info)
8-22-12:
  1. Sync'd with CM10
  2. Fixed: Boot to recovery(was just rebooting)
  3. Fixed: Boot Animation(proper CID for CM10) CID info here
  4. Fixed: Home Key(works correctly now)
  5. Fixed: Camera participle fixed(starts and takes Pic's, but screen gets distorted) Thanks to thekraven(for pointing out the fix was available) & hephappy(for the sharing the fix)
  6. Fixed: Camera Panorama View participle fixed(starts and takes Pic's, but screen gets distorted) Thanks to thekraven(for pointing out the fix was available) & hephappy(for the sharing the fix)
8-18-12:
  1. Initial Release
  2. Sync'd with CM10
  3. Removed: VideoEditor, foreign dictionaries, foreign keyboards, foreign fonts, large ringtones, Live Wallpaper, CM wallpaper, and CM ringtones
  4. Kernel v4.1
==== '''Download Links''' ====
NOTE: First Boot takes about eight minutes on my phone, be patient!
NOTE 2: If you end up having issues, always go back and try wiping. Start fresh and see if things don't improve.
NOTE 3: It'll take awhile for everything to settle down. Especially after installing gapps and syncing accounts. Give it a few minutes to settle and reboot a couple times. The system will speed up after that.
Build 11/3: cm-10.0.0-RC0.VM670.BobZhome.11032012.zip MD5checksum= e14bd8b497c3c7eb90c26a3e714ba99e
Custom Gapps(smaller): gapps-jb-20121011-BobZ.zip MD5checksum= ab5c22c9ac04a8663f232355715a29a0
NOTE: The ROM and the Latest Gapps(below) are so big that the Gapps will not install correctly because the phone runs out of room.
Latest Gapps: gapps-jb-20120726-signed.zip MD5checksum= f62cfe4a827202899919fd932d5246d7
ClockworkMod Recovery: VM670NH_recovery.img MD5checksum= 4196aac89f95ee7b468c53b5ffacf9db
==== '''Helpful Tips''' ====
Overclocking is available in Settings --> Performance --> Processor. Tweak it as you like, but know this: not all OV's were created equally.
==== '''Q & A''' ====
Q: What Baseband will this work on?
A: It works with all current Baseband, you do NOT need to update your Baseband, I'm still on ZV4
Q: Do I need the VM670NH recovery to install this ROM?
A: No, it's the one I use and recommend
Q: Can I use an A2SD script with this ROM?
A: No need...the rom will move your apps and dalvik to the EXT partition on your SDcard, if you have an EXT partition!
Q: Do I need an SDcard with EXT partition to install this ROM?
A: No, but it is very recommend to have one.
Q: Why was so much removed from your ROM?
A: This OS is so big it leaves very little room on your phone for your stuff.
Q: What do you mean by "foreign"?
A: Anything other than English and Spainish.
Q: Why was Dalvik-Cache moved back to the Data partition?
A: Gapps did not like it being on the SD-EXT partition and you would get the "Optimizing app x of xx" with every boot up. NOTE: Dalvik does get really big in JB, you may run out of room in Data if you have a lot of apps.
Q: What is with the new custom Gapps?
A: The ROM and Gapps are way to big for this phone, both needed to be slimmed down in order for them to install correctly with them as functional as possibly. Gmail was removed from the Gapps, but it is downloadable from the Play Store. Google Now is partially functional and Voice Search is totally broken.
Q: Why did you change scripts?
A: The A2SD++ script is written better, which allowed me to put Dalvik-Cache back on your SD-EXT partition without any issue. I did edit out parts of the A2SD++ because there is no easy way to erase the Apps-Private and Apps-Data info from the SD-EXT, so I wanted to keep the info on the phones DATA partition. Keeping the old info when flashing a new ROM creates issues, just like when you do a dirty flash. Also I found the ZipAlign did not work as well as the one I was using, so I removed that part of the code from the new script.
==== '''Resources''' ====
https://github.com/BobZhome
Enjoy!
Master Gowa
Active member
Jun 24, 2012
28
4
Thanks Bob. Been dying for a pure OV Jellybean rom. Zakman's port was good but I can't wait to try this. BTW... they found a slimmed down keyboard that's only 2 megs (if you aren't already using it). Also would this rom benefit from Amphetamines or MiRaGe's EGL patch? :-$
YoshinJaa
126
29
Anyway the gapps could be slimmed? Also is the home button messing up for other people? Like when you press it, it highlights the nearest selectable object on screen? Also, after clean wiping, I didn't have the opportunity to sign into google for account restore.
YoshinJaa
126
29
The Gapps is probably too big, try my slimmed gapps: gapps-jb-medium-20120816-signed.zip
I noticed that GNow srec folder is in the OP posted gapps, so I flashed it twice and am now rebooting. Will report any changes if possible. I will try flashing the medium gapps afterwards.
EDIT: no change after flashing OP gapps twice. Still no first time sign in setup. Now flashing medium momentarily.
Reactions: Zakman
YoshinJaa
126
29
Flashing medium gapps didnt really affected anything either. No play store, so its kinda hard to install any app. Trying to figure out a way to get the play store with no restrictions onto it.
YoshinJaa
126
29
So far the bugs/issues I have noticed are (only if you flash the ROM ONLY without gapps):
- No Play Store, so no immediate download of file managers/Titanium Backup/Apps
- Home key button is not set correctly
-Gallery does not display pictures
-CM9 boot animation instead of CM10
What does work:
- Wi-Fi
- Bluetooth (did not test connectivity; but you can toggle on/off and it does not cause a reboot)
I tried to use adb to push and install but i was having errors on installing device drivers which I already have. Anyone else tried to use adb?
I believe this is a usb mass storage issue with the ROM, I can detect my phone as a usb composite device while in recovery
I'll update this post with any other findings
Reactions: BobZhome
Zakman
492
185
So far the bugs/issues I have noticed are:
- Default Browser app flashes but does not open
- Settings button in Notification drawer does not work
- Google Sound Search (via widget, getting FC's)
- No lock screen
What does work:
- Wi-Fi
The home key issue has nothing to do with the char and layout files, just replaced them, hmmm wierd
Reactions: YoshinJaa
YoshinJaa
126
29
I tried adding the no device restriction Play Store to the rom zip, and it seemed to have disappeared Google account sign in when trying to add an account via system settings. However, the Play Store did show up in the app drawer.
ThatGuyLurkin
2,155
665
I lol'd when you listed the bootanimation as a bug.
@Bob, maybe remove the bootanimation for even more room? 2-4 MBs I think.
fallingOutOfLoveWfithTech
