[ROM][WIP]CM10.0.0-RC0-BobZ
Conrail16
118
22
So, all the other issues from CM9, like GPU drivers have been resolved on this CM10 ROM?
The graphics driver issues are not solved here, and likely never will be solved due to Qualcomm's unwillingness to release them compiled for ARM6 (unless someone figures out how to reverse engineer them or make a wrapper for the GB ones- both of which would be very difficult tasks).
Reactions: r00t
YoshinJaa
126
29
Probably cause i modified the zip and replaced latinime with the 2mb one
If it isn't much trouble, could you upload this modified zip? I still cannot get first time account restore, it goes boots straight into the home screen.
Zakman
492
185
These darn keys!! I can't seem to fix the key issue ATM will keep trying tomorrow, for now I'm using button savior, gonna get some rest now, brb tomorrow
HurrrDurrrDURP
356
111
Got GApps to work by moving them to /data and to their respective folders. No glitches or durps, I think we can get gapps to fully work by pushing it all there.
So we just need to write some custom GAPPS and we are all good to go ;)
if we change its ownership to root and chmod them to 644, we are good :)
Zakman
492
185
@bob maybe if you make another build from source when it updated the home key will be fixed, i cant figure out whats causing it :/
Zakman
492
185
@Bob also the kernel has a menu and home buttons swap on it, maybe something to look at
19escape20
