BobZ, Thanks for your work on this, it is really a lot better than I expected at such an early stage. The screen sensitivity is way off scale as I barely touch it to get a response instead of continually hitting it over and over. The squareup credit card reader even works. So far, all I have come across that doesn't work for me is my bluetooth headset (jawbone icon). It does some strange stuff. Hopefully when the bluetooth gets fixed, we won't loose the squareup reader as in IHO's CM7 and Tdm's CM9. Since it happened in both ROMs when the bluetooth was fixed, maybe you can avoid the "fix" that they both used since I am pointing it out fairly early to you. Again, thanks so very much for your work.
