capslock118
I build my ROM's to my liking...no one forces you to use it...there are plenty of others to flash :-*
I meant no disrespect.
Is there a lag between the time your apps2sd code kicks in and when the apps are downloaded?
During restore google play automatically starts downloading all my apps. Easy but I do end up hitting the upper limit of internal storage about half-way through; apparently I use a lot more than 20 apps.
Camera still seems a bit glitchy by the way.
