Pomman
I did clean installation. Is it still not fixed??. Thanks for hard work BobZ.
Sent from my type-R using Tapatalk 2
I do have p.store. home is works but only 20% of 100%.
Voice commands like texting work, just not search queries.
I'm sold on this ROM, but really miss web search from the home screen widget. I'd gladly trade Google Now for ICS search. Any way to pull this off?
Brightness control is broken.
Thats all I found....
Or you could turn off Google now
Go to goolge now press the menu button tap the setting option than go to Google now than slide the "on" button to off
Your out of space on DATA partition? Your apps should be on SD-EXT, correct? And you moved your app/data...so your telling me Dalvik is using up 187MB?@BobZ, is there anyway to remedy only being able to install a few apps before internal starts notifying of low storage space? I used TiBackup to move user app data to sd card(to sd-ext/data2), and that seemed to have freed up some internal memory, is there any other suggestions?
