Just wanted to say a quick thanks for the development of this ROM.
I installed the ROM and so far I really like it, seems very smooth so far.
I did also install the full gapps for jb, I don't use that many apps, and after install there was about 67megs of space left. I do also have an sd-ext partition on my sd card.
And with the apps that I do have, which I think at most I use 10-12 everything seems fine thus far on that end, haven't run out of space, yet, lol.
I've only run into two problems thus far, but I haven't had a whole lot of time to fully play around with it and check it out fully yet.
1)YouTube will work sometimes, play a video, and then the phone will reboot, also sometimes it just will reboot completely before loading a YouTube video (non HD videos just to clarify on it)
2) The WiFi symbol seems to disappear sometimes, still have the WiFi connection when it happens, but it only seems to disappear so far after it reboots, as with YouTube. Turning it off and back on seems to work for now as a fix.
That's all I've noticed so far. Just thought I would share that.
Again, great ROM so far, really looking good.
