[ROM][WIP]CM10.0.0-RC0-BobZ
anthonycr
Themer. You've seen them
Jul 11, 2011
2,104
571
@BobZhome, any idea when a new build will be coming along? Or you waiting for more bugs to be found?
I don't know any more than you, but judging from his CM9 Rom (which gets updated every time CM hits a new milestone and sometimes in between) I'd say he's probably waiting for CM to reach M1, which it in fact reached just the other day, so I'd bet we see a new build soon. But I could be wrong...
BobZhome
296
627
I'm remodeling a room in my house, so my time on the PC has gone down...but I have gotten brightness, proximity sensor, and baseband info fixed and was hoping to get one more thing fixed...probably in a few day with what I have.
- - - Updated - - -
Got a question for Bob. Is your ROM compatible with superchargerV6 or is this a moot point and is already installed, or not able to work with JB?? Also can the same be said about turbocharger V3 ?? I only ask because if they are compatible and not already implemented I will test and give results if it works and if it makes a difference. Just not sure I wanna take the risk of doing it if its already done, or not even possible.
Try it and let us know how it works out for you
me2151
272
123
@ Bob. See what i ment in my second PM? it MIGHT work. i would need to get source and stuff and i really dont have the space on my laptop. maybe when i get my desktop back up this weekend.
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
I smell a rom brewing in the distance
Sent from my LG-LS670 using Tapatalk 2
koeylondon
226
Hey,
While I know this is a V rom, I was (like others) really wanting to put this on my S, which should (in theory) work. However, I'm receiving an error, which may be my phone being punky or in the rom someplace. Either way, I'll post my log here. Hope to see a version I can flash!
  • recovery.txt
nerdmastax
101
3
wow remodeling a room? sounds nice, care to share what you've done on it, or even a pic?
screw the rom... lol j/k
- - - Updated - - -
Code:
script aborted: assert failed: getprop("ro.product.device") == "thunderc" || getprop("ro.build.product") == "thunderc" ||
       getprop("ro.product.device") == "VM670" || getprop("ro.build.product") == "VM670" ||
       getprop("ro.product.device") == "thunderc_VM670" || getprop("ro.build.product") == "thunderc_VM670" ||
       getprop("ro.product.device") == "LG-VM670" || getprop("ro.build.product") == "LG-VM670"
assert failed: getprop("ro.product.device") == "thunderc" || getprop("ro.build.product") == "thunderc" ||        getprop("ro.product.device") == "VM670" || getprop("ro.build.product") == "VM670" ||        getprop("ro.product.device") == "thunderc_VM670" || getprop("ro.build.product") == "thunderc_VM670" ||        getprop("ro.product.device") == "LG-VM670" || getprop("ro.build.product") == "LG-VM670"
E:Error in /sdcard/Roms/BobZ/cm-10.0.0-RC0.VM670.BobZhome.08312012 (1).zip
looks to me like the updater script is looking for a different device, perhaps you need to edit it? i think there is a tool to convert it that you need to do first,
r0gu3dev1pr
92
15
Hey,
Some Recoveries enforce the asserts. From your log, it looks like you are using Drew's COT. You can still flash this ROM on a Optimus S you just have to remove the asserts. On your PC, open the ROM.zip with 7zip then navigate to META-INF\com\google\android\updater-script. Remove the only first line. (from assert to the first semicolon, including the semicolon.)
BobZhome
296
627
What works on GB may not work in ICS or JB. Code changes with ever update...that is why the dev's have to re-fix things.
GB version of the file you stated: https://github.com/CyanogenMod/android_bootable_recovery/blob/gingerbread/extendedcommands.c
line 360 is what needed to be changed...
JB version of the same file: https://github.com/CyanogenMod/android_bootable_recovery/blob/jellybean/extendedcommands.c
line 360 is no where to be found!
The demo work is complete...my house is 100 years old, so I had to take down the plaster, lathe, and ripped up the floor also. The studs are 24" apart, so thats a 12' wall...the floor joists are only 2x6's with a 12' span and 24" on center it made the floor bounce and it dipped in the middle. There was no insulation and only one receptacle in the room...the pipes sticking up in the right hand corner are from a cast iron radiator.
This was way off topic, sorry, please PM me if you want any more info on my room.
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
Just flashed this, it's awesome, runs well. However, I noticed that it doesn't seem to include a camera app? I downloaded the ZIP twice to make sure. Grabbed Camera ICS off the market, and it works (sort of.) Did a quick search in the thread and didn't see this mentioned yet.
me2151
272
123
Its line 496 in JB :/
flapjack.fiasco
776
102
In the OP, changelog for the 8/31 build, item 6 mentions the camera, but in the context of a kernel tweak that improves it. I'm pretty sure that I played around with the camera when I flashed it, in fact, I believe I remember panorama mode even working.
So that's really weird, but my first flash, with the correct gapps, was missing play store, so go figure.
upconvert
486
3
What happens when you press the camera hard button?
kirk781
