Zakman
Still some sort of a data issue, if you leave it sit in your pocket it disconnects and sometimes you cant toggle anymore and have to restart.
Almost perfect rom with some tweaks it is the best
Like Amphetamines? Tried it. Seemed to turn the ROM a wee bit unstable, like it was going way too fast and smooth for it's own good. Good thing I carried a backup...the EGL patch worked fine though.
It works well for me. Have Amphetamines, egl and adrenaline boost v3.
I believe this is what your looking forCan I get a link for these I have amphetamines just egl by the way what is egl and a link to the v3 thank u!
Sent from my LG-VM670 using Xparent Pink Tapatalk 2
Disable CPU Rendering (EGL)
http://forums.androidcentral.com/showthread.php?t=187973
Adrenaline Boost V3
V3 | ➣Adrenaline? Boost For All Android Devices ! | 5/4/2012 - xda-developers
This is the Hash tag I am getting.
63f47c5fba33991d3e5048d546c15107
7c5fba33991d3e5048d546c15107 This is the one in the First post. I think it's the same and BobZhome some how missed the 63f4 when he copied and pasted it into the post.
is the google play store app in the custum gapps now
---------- Post Merged at 09:48 AM ---------- Previous Post was at 09:48 AM ----------
I/O scheduler is set by kernel, I'll change it to default to Deadline with next build...people that can OC can change it very easily now.
Well I guess I'll just have to fix that then won't I.....lol
---------- Post Merged at 03:13 AM ---------- Previous Post was at 03:08 AM ----------
http://www.mediafire.com/?3xyepg2wyjgyawo ..... There, try that?..lol
