upconvert
Hello Everyone,
Are there any patches/updates that fix the USB Tethering and USB Mass Storage issues? Also, when it says that 'WiFi Tethering' doesn't work, is that referring to the 'Built-in' WiFi Tethering or is it saying that we can't even use a WiFi Tethering app from the market?
Thanks!
BJ
USB mass storage can be fixed by toggling adb on and off. At least I think that was this rom. Maybe that was on cm9. WiFi tether apps work for the most part. I can tether my pc, but not my tablet. I've had that problem on several roms, including the stock, but the native wifi tether on cm7 works fine. No fixes for usb tethering, as far as I know.
