flapjack.fiasco
True but I under clocked back ro regular settings and the camera still f*cks up
Okay, so what exactly do you mean by that? Does it force close?
Thanks for the heads up on the new 'Developer Options'. Yes, I made sure that it was checked. Still no ADB though, nor do I have lockscreen. Hmmmm.
BJ
Noob ?: I can't get gapps working either. How does one access the system partition to try to fix?
Use the root file manager, open it go to system and delete some apk, ect just enough to flash Jb-gapps!!
That won't work. You need to open the ROM up with winRAR or 7zip on a PC. Don't extract it, just open it. Then you need to delete some apps from the system/apps folder (things like email, Apollo, etc.), maybe switch out the LatinIME.apk for a smaller one. Someone else using an Optimus S did this a few pages back on this thread. Read what they did.
Why would u want to delete browser?
Sent from my LG-LS670 using Android Central Forums
I've never used Apollo. Do other music players have issues for you?
Repensum Est Canicula
so i'm trying to figure out why wifi doesn't work - specifically infrastructure AP mode. This works in gingerbread builds and I am assuming here this is an issue with the wpa_supplicant? well that might not be the issue because when I take the wpa_supplicant from the Harmonia build that just doesn't work at all.
shouldnt this wifi issue be a firmware and/or kernel thing? and if so, if it works in a previous rom why would software i.e. jellybean os impact that?
