[ROM][WIP]CM10.0.0-RC0-BobZ
0vermind
The mic doesn't work with apps on this release. Two releases ago, it was working, but I don't remember the date on that one. If you read back a bit in the thread, you should be able to find it.
Microphone isn't working for me with apps either. I use GrooveIP to make calls and I can hear the person but they can't hear me. I also tried bluetooth and all I hear is loud static. /:
AndyOpie150
1,254
32
Man I really hate to sound newbish, but, everytime I try to install the ROM and Gapp's I don't get the PlayStore in any shape, form, or fashion. I opened the Gapp's zip and didn't see the vending.apk.
bebostar
Wow!!! Dude I downloaded flashed everything royalty flawless man I don't care for what's not working but it would be nice just to have, this is my new daily driver :) keep up the awesome work,,oh are there any new updates coming and if you could add Chinese to language thanks man I love it you deserve a novella prize :)))
petex420
6
I would love to use this as it is simply the best looking rom for the OV. However... My phone constantly reboots with this rom and I don't know why..... It will freeze up randomly and then just do a hard reboot.
AndyOpie150
1,254
32
Have you made a 2GB ext.3 partition on the SD card from the recovery?
Also: From the recovery did you wipe data/factory reset, cache partition, dalvik cache. Also, did you format boot, cache, data, and system.
One last question : Did you have the PlayStore when it booted from recovery?
petex420
6
yes I have an sd-ext partition, I did the factory reset on my phone that whipes everything. I also tried installing it a second time, no dice. still freezes up randomly. I did have the play store, as I flashed the 'small' gapps like it said in the opening post. Thanks for the help though I would really like to get it to work. also my phone is not overclocked and I touched nothing in performance.
drezliok
451
54
I've found that the factory reset fails to do a full wipe. I format each one manually in recovery.
thewraith420
1,987
223
63
Factory reset does not do a full wipe. It formats /data, /cache, and /sd-ext on cot recovery
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ firmware
petex420
6
I just did them all manually and it still froze twice in a row while entering my email address and putting in my wifi password.....
brotherswing
555
167
There is no battery savings below 480 on the Arm6. However if it's clocked lower than that, it takes more juice to ramp up the speed. Therefore keeping the minimum at 480 is the most efficient.
Repensum Est Canicula
petex420
6
ahh I see, well changing the min to 480 solved my crashing issue. but I found out it is not mounting my EXT partition? I can do it manually..... but it isn't copying apps to it like it says it does in the OP
Ok so it appears my 32gb sd card was failing after 6 months so that was causing the sd-ext to not be mounted. popped in a 2gb and its working fine.
bnutz
