Will a 16GB micro sdhc work for my optimus v? It's saying it only has 32mb of storage and i can't format.
Yes it will work. That's what I use. Try using something like EaseUS on your pc to format it first.
Which tool?
EaseUS partition manager
Format or partition? If you're formatting, then the partition may only be 30MB big, in which case you will never be able to format anything larger than that (unless you resize the partition). I'd suggest backing up the data (if you have any), deleting the partition (and any others), making a new partition as big as the SD card (if that's what you want), then formatting (and it'll be ~16GB this time).It didn't work...I'm pretty sure that SD is just faulty. -__- Still only letting me format 30.6 MB
But, basically, formatting and partitioning are 2 different processes.
No, I bought the Sd card brandnew and when I put it in my computer to put music on it, it said I need to format it, so I tried and it said something about a lock and I've tried many tools, and all say I only have 30.6MB on the card. There's no hidden partitions or anything...It's new. Never used straight out of the package.
Where did you buy it? I've heard about sd-cards being sold on eBay that are not what they claim to be.
I have a problem with my 16gb SD card after i droped my phone! It only mounts as read only there for I can not take more pic from my camera , I tryed reformating from recovery but it does not format my SD card? Strange? Also I deleted everything on my SD card using my computer but when I put it back on my phone.....all the info on the sdcard is back????? Strange ? Can I still save my SD card???? Any help please!!!!!
It seems as if your micro SD card is locked
Sent from my Chocolate Chip ICS
