1. cpackar's Avatar
    So I flashed a new recovery onto my VM670, and here's pretty much how the button key is layed out:
    Power - Hides Options
    Volume Up - Nothing
    Volume Down - Moves Selector Up
    Key Above Camera Key - Moves Selector Down
    Camera Key - Goes Back
    Search Key - Moves Selector Down When Double Tapped
    Back Key - Moves Selector Up When Double Tapped
    Home Key - Nothing
    Very Left Key - Nothing
    When I first flashed it and booted into recovery, I could select options with the Power Key, so I wiped everything after I backed up, and rebooted and now Power Key just hides the options and I can't select anything. So I can't boot into Rom, and I can't do anything with Recovery mode. What should I do? If it helps, I downloaded ROM Manager and used it to flash a new recovery. It said something about an Optimus C, so I clicked it figuring it should work. It's ClockworkMod Recovery v5.0.2.7. Just reply here, or PM me please.
    08-26-2012 07:15 PM
  2. lattimorej1986's Avatar
    Good ole rom manager again, huh?
    Looks like this will never end guys.
    OP, you flashed a recovery that isnt designed for our phones. You will need to flash a new recovery. A brief look around these forums will get you going in the right direction.
    And do yourself a favor, stay away from rom manager, if not forever, then atleast while you have an optimus.
    08-26-2012 07:29 PM
  3. cpackar's Avatar
    That's the problem, How will flash a new recovery? I can't boot into android because I did a wipe.
    08-26-2012 07:32 PM
  4. clodfelterac's Avatar
    08-26-2012 07:44 PM
  5. cpackar's Avatar
    Okay, I got adb running, now how would I flash a different recovery onto my phone via adb?
    08-26-2012 08:28 PM
  6. ThatGuyLurkin's Avatar
    Errrm. I'm a little rusty on ADB for ashing, but. Put the Recovery on your SD card and name it x.img
    You also need flash_image on your SD card
    You will then type
    1. Su
    2. CD sdcard
    3. Flash_image recovery x img
    4. Reboot recovery
    It should be in the new recovery if you did it right.
    08-26-2012 10:34 PM
  7. cpackar's Avatar
    You will then type
    1. Su
    2. CD sdcard
    4. Reboot recovery
    What do you mean by "You also need flash_image on your SD card"
    08-27-2012 01:24 AM
