[INIT.D SCRIPT] Tweaked Loopy Smoothness
LeoLawliet
713
108
This tweak was originally developed by lpy at XDA, here's the link to his thread. http://forum.xda-developers.com/showthread.php?t=1137554
Honestly been too preoccupied to update the op, my bad guys. Thank lpy before you thank me, and you can always use the original script to tweak however you like if you feel like it :)
I read the tutorials for it and learned how to set it up, it's worth putting the time into it. Anyways, this should speed things up with Apex Launcher, a few system apps, Google Voice, N64oid, and various other apps with the settings sorta tweaked a bit differently from the original. Anyways I hope that someone will benefit from using this tweaked smoothness script. You can easily edit it as you like with Root Explorer, just open in Text Editor. Set the permissions like this
Enjoy and feel free to thank me if you like, but all credit goes to the original creator of the script, all I did was change the settings he intended for us to play around with :)
https://www.box.com/shared/6gm6hrpcete9nebksk16
Sent from my LG-E739 using Tapatalk 2
LeoLawliet
713
108
Your running AOKP? That lookd sleek and clean bro! :thumbup:
Nope, ICSyndicate. It's a tweaked version of the stable CM9 releases for the LG myTouch 4G.
I wish it was ParanoidAndroid, but there's not a single dev working on it.
LeoLawliet
713
108
I would ask for the favor but I don't know anyone who is willing or has the free time to compile it. If I had a working laptop I'd learn it and do it myself but I can't :/
I like learning things hands on
YoshinJaa
126
29
off-topic: Is there a ICSyndicate built for the OV? The whole layout is amazing. Would definitely run that in a heartbeat
on another note, this script really speed up the smoothness of BobZ cm10 rom. Thanks :)
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
Leo, can you update your OP to actually give credit to the original creator of the script? It says that "all credit goes to" them, but we have no idea who they are, lol.
A-android-B
414
21
How exactly does one use this? I downloaded but I don't see any file extension. Do I rename to .zip and flash? Or do move somewhere with file explorer? Any advice appreciated
adamhos
645
22
Open in text editor ( root browser works good for this)
Select all, copy
Paste in terminal editor
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
If its for an mdpi phone I could try porting :thumbup:
Sent from my LG-LS670 using Tapatalk 2
LeoLawliet
713
108
Will do, just been really busy x__x
I believe lpy made the script, gonna look it up now
It's an hdpi device, if you want I could direct you to the thread for the rom
A-android-B
414
21
Select all, copy
Thanks for the directions man worked like a charm I love root browser by jrummy!
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Please do so thx
See if I can do something tvall said I can use his rom so happy time
ThatGuyLurkin
2,155
665
I'm confused. Can I copy to System/etc/Init.d and remove the .bin file extension?
Also, can you link me to? I wanna see screenies. :)
fallingOutOfLoveWfithTech
