This tweak was originally developed by lpy at XDA, here's the link to his thread. http://forum.xda-developers.com/showthread.php?t=1137554
Honestly been too preoccupied to update the op, my bad guys. Thank lpy before you thank me, and you can always use the original script to tweak however you like if you feel like it
I read the tutorials for it and learned how to set it up, it's worth putting the time into it. Anyways, this should speed things up with Apex Launcher, a few system apps, Google Voice, N64oid, and various other apps with the settings sorta tweaked a bit differently from the original. Anyways I hope that someone will benefit from using this tweaked smoothness script. You can easily edit it as you like with Root Explorer, just open in Text Editor. Set the permissions like this
Enjoy and feel free to thank me if you like, but all credit goes to the original creator of the script, all I did was change the settings he intended for us to play around with
https://www.box.com/shared/6gm6hrpcete9nebksk16
Sent from my LG-E739 using Tapatalk 2
