1. heloworld's Avatar
    I go to my recovery to change my rom, and it wont read my sd card. but when im on the phone it can read it. idk what to do\= helppp! pleasee! Thanks in advance!
    09-10-2012 12:31 AM
  2. carloswii5's Avatar
    What recovery
    Sent From My ICS Xperia
    09-10-2012 12:35 AM
  3. heloworld's Avatar
    ra-opts-2.2.1-gnm its always worked, until now \= idk what to do.
    09-10-2012 12:45 AM
  4. carloswii5's Avatar
    Mmm I don't know maybe flashing another recovery since you say that when you boot up your rom it reads it maybe its the recovery
    heloworld likes this.
    09-10-2012 12:49 AM
  5. clodfelterac's Avatar
    - enter recovery from the powered off state using the key combo (hold home/vol down/power, do not release until after the lg logo appears)
    - go to install zip, does it pull up the contents of your sd?
    - if no, eject sd and put it back in
    - if no, go to mounts/storage
    - is sd mounted? toggle it on/off?
    - if no, pull the battery and replace
    - repeat the above--^^
    - if this doesnt work, i would try reformatting/repartitioning the sd, (be sure to make a copy of your sd contents to a pc before you attempt the sd format/repartitioning), then transfer it back via mounts/storage>mount usb storage
    - repeat the install process
    could work... :-)
    and its probably time to upgrade you recovery:
    http://forums.androidcentral.com/lg-...13-2012-a.html
    09-10-2012 12:50 AM
  6. heloworld's Avatar
    i dont know how to flash another recovery.. lol .///
    - - - Updated - - -
    could work... :-)
    i tried this all, thank you tho :]
    09-10-2012 12:52 AM
  7. carloswii5's Avatar
    - - - Updated - - -
    Search recovery flasher utility on market and ddownload and do w ha t it says and I recommend cannibal open touch recovery
    heloworld and anthonycr like this.
    09-10-2012 12:55 AM
  8. clodfelterac's Avatar
    follow the link and dl the alternate flash installer, flash it in recovery like normal, but when its finished, find and use your recoverys option to reboot recovery... :-)
    09-10-2012 12:56 AM
  9. heloworld's Avatar
    Thank you guys very much! i will do that, ill let you know what happens !!
    09-10-2012 12:58 AM
  10. heloworld's Avatar
    i did it, but when wiped everything to install a new rom it backed up, after the the screen went blank, im scared to pull out the battery.
    - - - Updated - - -
    - - - Updated - - -
    nvm lol
    - - - Updated - - -
    nvm lol
    09-10-2012 11:01 AM
  11. carloswii5's Avatar
    - - - Updated - - -
    - - - Updated - - -
    nvm lol
    - - - Updated - - -
    nvm lol
    So did it work?
    09-10-2012 09:24 PM
  1. Yahoo mail email help please!!!!
    By ciscocv in forum General Help and How To
    Last Post: 12-12-2009, 12:58 PM
  2. Internet Not Working - Help Please?
    By thezob101 in forum General Help and How To
    Last Post: 10-30-2009, 09:03 PM
  3. help please
    By aquaj13 in forum HTC Hero
    Last Post: 10-14-2009, 10:40 AM
  4. roadblock to getting started- help please
    By theworldends in forum General Help and How To
    Last Post: 07-13-2009, 03:13 AM
  5. need help please
    By jfchica1987 in forum T-Mobile G1
    Last Post: 06-16-2009, 02:12 PM
