I'm having the normal battery drain/lost signal problem, so I think it'll be easier to just root and flash a rom for a permanent fix.
The most important things are, in order of appearance:
battery drain problem fixed
reliable reconnects after data loss
built-in flash (if possible)
ease of use/reliability
customisation (appearance, overclocking, etc)
googleplay compatability (if possible)
Thanks for the help!
