1. Redchigh's Avatar
    I'm having the normal battery drain/lost signal problem, so I think it'll be easier to just root and flash a rom for a permanent fix.
    The most important things are, in order of appearance:
    battery drain problem fixed
    reliable reconnects after data loss
    built-in flash (if possible)
    ease of use/reliability
    customisation (appearance, overclocking, etc)
    googleplay compatability (if possible)
    Thanks for the help!
    09-28-2012 01:52 AM
  2. redrunner1985's Avatar
    I would suggest tvall's iho magpie. I used it for months and loved it. I use my music player a lot for hours on end and never had issues. I was also able to oc to 122/864 with it staying completely stable. It has all the cm customization to go with it. It also has app2sd built in.
    Sent from ACF Dark
    09-28-2012 02:21 AM
  3. Badboytoast's Avatar
    I would recommend gingersnap!!
    sent from vm670 running bobz Jb
    bkttk2 likes this.
    09-28-2012 01:32 PM
  1. Help me choose a phone for my teenage daughter
    By plentyz in forum General Help and How To
    Last Post: 06-21-2012, 10:05 AM
  2. Just rooted - ROM suggestions for my needs?
    By scosch in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 12-17-2011, 09:02 PM
  3. ROM for my MOM
    By idkmybffjill in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 03-09-2011, 10:22 AM
  4. Best Launcher For My Needs
    By kg6bki#AC in forum Android Apps
    Last Post: 10-05-2010, 12:58 PM
  5. Replies: 1
    Last Post: 07-07-2010, 01:57 PM
