AndyOpie150
To get the best results. Use the partition SD card option found in a custom recovery like the ZenGarden recovery. Developed by the previous poster.
You can only use no more than 20% of the actual storage space on the SD card for a partition, but Link2SD works best with a 2GB partition. You need an SD card with enough actual storage space, that at the very least, will allow you to to have a 1GB partition.
If you use an 8-32GB SD card it is almost imperative that you use the recovery to make the partition. You can then change the partitions format to whatever you need with Mini Tool Partition Wizard.
I like to flash a fresh ROM then install Titanium Backup ,widget apps, Root Uninstaller, and Link2SD.
Open up Link2SD and choose the format of the partition you made on the SD card. Then reboot.
After your phone revolts, open up Link2SD and go to the menu and select the "Auto Link" function.
Close and then open up Titanium Backup. Restore your apps.
