1. chaosmaster84's Avatar
    Okay so I have the Lg optimus V from virgin mobile . And I would always flash different roms onto it just to try them out .
    Recently I flashed the JellyBean WIP Alpha 7 rom . And I kinda wanted to go back to another rom . But whenever I try to flash any other rom onto my phone It says that the installation failed .
    Help ?
    10-08-2012 01:49 PM
  2. Encerspay45's Avatar
    Did you make a backup and wipe everything?
    10-08-2012 01:50 PM
  3. chaosmaster84's Avatar
    I forgot to make a backup when I flashed the JellyBean rom :/
    10-08-2012 01:54 PM
  4. chaosmaster84's Avatar
    10-08-2012 01:55 PM
  5. Encerspay45's Avatar
    Backups are always the golden rule for flashing.
    But you know that now.
    Anyway, can you boot into recovery?
    (with the phone off, hold power button, home button, and up volume button for about 10 seconds)
    10-08-2012 01:59 PM
  6. chaosmaster84's Avatar
    Yep . I still can .
    10-08-2012 02:06 PM
  7. clodfelterac's Avatar
    you should be fine, you just dont have a backup to restore if things like this **** up...
    boot to recovery>
    mounts and storage>
    format boot>
    format system>
    format data>
    format cache>
    format sd-ext (if you have one)>
    format dalvik>
    flash rom/gapps>
    reboot>
    if you still get install aborted, try disabling signature verification before flashing, or download fresh copies of whatever rom/gapps youre wanting to use, and follow the method above... :-)
    10-08-2012 02:09 PM
  8. chaosmaster84's Avatar
    boot to recovery>
    mounts and storage>
    format boot>
    format system>
    format data>
    format cache>
    format dalvik>
    flash rom/gapps>
    reboot>
    I'll try that . Thanks [:
    10-08-2012 02:14 PM
  9. chaosmaster84's Avatar
    boot to recovery>
    mounts and storage>
    format boot>
    format system>
    format data>
    format cache>
    format dalvik>
    flash rom/gapps>
    reboot>
    I Still Get the installation aborted .
    10-08-2012 02:18 PM
  10. adamhos's Avatar
    What recovery are you using and what rom are you trying to flash?
    Have you tried a fresh download? You could have a corrupt download of the rom you are trying to flash
    10-08-2012 02:22 PM
  11. chaosmaster84's Avatar
    boot to recovery>
    mounts and storage>
    format boot>
    format system>
    format data>
    format cache>
    format dalvik>
    flash rom/gapps>
    reboot>
    And Actually I'm trying to flash your Gs3 rom
    10-08-2012 02:22 PM
  12. chaosmaster84's Avatar
    Rom Manager Clockwork mod . And I don't think so . Because all the other times every rom worked perfectly until this jelly bean problem happened .
    10-08-2012 02:23 PM
  13. Encerspay45's Avatar
    ROM Manager is bad for the OV, it can end up in a brick if you slip up.
    I used Jerry's Green Recovery and it's great.
    10-08-2012 02:29 PM
  14. clodfelterac's Avatar
    ROM MANAGER is NOT compatible with our phones...
    http://forums.androidcentral.com/opt...tart-here.html (post#2)
    Im extremely suprised youve made it this far... flash twrp asap and follow the instructions as per the op... :-)
    10-08-2012 02:29 PM
  15. chaosmaster84's Avatar
    Ok .
    Oh wow . I never knew .-.
    10-08-2012 02:33 PM
  16. chaosmaster84's Avatar
    It worked . Thanks ! [:
    <3
    flapjack.fiasco likes this.
    10-08-2012 02:53 PM
  1. Can't get any ICS roms working! Please Help.
    By fonzilla in forum HTC EVO 3D Rooting, ROMs, and Hacks
    Last Post: 06-04-2012, 07:37 PM
  2. Can you flash any ROM on any phone?
    By TGreg104 in forum Droid Charge Rooting, ROMs, and Hacks
    Last Post: 10-01-2011, 10:47 PM
  3. Can I flash any rom over the rooted gingerbread leak?
    By jbomb11 in forum Droid Charge Rooting, ROMs, and Hacks
    Last Post: 09-21-2011, 10:11 AM
  4. CANT BOOT TO ANY OTHER ROM BUT CM6 and need to activate!
    By chaosrecords in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 09-23-2010, 07:46 PM
  5. Used unrEVOked 2 or 3 and can't flash a custom rom? Check here!
    By Tattrpuff in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 07-26-2010, 01:36 PM
