1. FullWolfMoon's Avatar
    Hello. I'm completely new to all of this. I didn't think I ever would bother, but I went ahead and dove in and rooted my phone a couple of weeks ago. After spending hours reading up on all of the precautions and how-tos so that I didn't brick it. It went smoothly and I'm thrilled with all the new things I can do with my phone now! It's really exciting. Like having a whole new phone! Thanks to all you wonderful people who worked so hard to make sure people like me don't screw things up too bad when we try this kind of thing, I was able to do it and not brick my phone! So, yay for that!
    I'm using Harmonia 2 ROM and love it.
    I'm not worried about battery life, since I expected it would run down faster and that's not an issue for me. But I noticed when my battery is down and I plug it in to charge it, it seems to go to 100 % (Or say it is anyway) pretty quickly. Faster than it ever did previously. It just seems like it charges too quickly or something. Am I to trust this is correct or could it not be fully charged, but somehow just saying it is? Is there a way to fix this if it's not fully charged but somehow saying 100 % anyway? I saw in the Recovery mode something about wiping battery, but I didn't touch that as I don't know what it does or doesn't do.
    Also, for the past couple of days I've had a lot of dropped calls, and problems sending SMS. When I've tried making calls, the call will drop or end immediately or shortly after I've placed the call. Not every time though. I think people have been having trouble getting through to me as well.
    I was using Go SMS Pro which really worked well for me, but all of a sudden after a reboot, it said it wasn't installed and I tried to reboot again, tried to take out the battery and reboot, tried to uninstall and reinstall the app, but when I attempted to install it again from the Play Store it goes through the download, then tries to install, then gives me an invalid message and won't let me do anything. I'm not having an issue with any other of my apps. I am now using Handcent SMS, which is OK, but I don't know if it's the app or my phone, but my messages seem to have a harder time getting through. Inconsistently, I am getting and sending delayed texts which is getting frustrating. But, I'm not sure if this is a phone problem, rooting problem, or service problem though. If this is anything that could be related to rooting and possibly fixed, I would appreciate any help.
    Thanks in advance for any replies!
    10-14-2012 01:29 AM
  2. ebrown761's Avatar
    I've never used Harmonia 2 so don't know the known issues with the rom but its always a good idea "when in doubt, do a fresh wipe and install", and with the battery i try to make sure with any flash to a new rom I'm ether at 100% when flashed or after flashed the first couple charges try n let your battery drain to 20 percent or below then leave plugged in till 100% that should set your battery stats
    10-14-2012 04:03 AM
  3. adamhos's Avatar
    If your issues continue I would also reflash with a clean wipe (don't forget dalvik cache)
    As for the battery, I would do as the post above says but add 1 step
    When it says 100%, unplug the charger then shut the phone off, then attach the charger and wait until the battery is solid
    This may take a couple charges to get you back on track and it may be total BS but seems to work for me when I have a battery 'drain' issue
    10-14-2012 06:37 AM
  1. New to Rooting; have a few questions.
    By Dan1192 in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 01-30-2012, 03:36 PM
  2. New to rooting, have questions first
    By TBolt55 in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 08-30-2011, 07:02 PM
  3. New to rooting, I have a couple questions
    By MengTian in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 07-11-2011, 10:14 PM
  4. Just rooted and I have a few questions
    By conductor_bosh in forum Barnes & Noble Nook Color
    Last Post: 05-24-2011, 05:00 PM
  5. Have a couple questions about rooting my droid
    By mjesenovec in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 02-11-2010, 03:02 PM
