Right now I use bobzhome 7.2, and I like it. I just want to give ics a spin. Will apps that require ics work on my phone, or will Google think I have stock?
Back on topic... I liked bobzhomes gingerbread, so I tried his ics. For some reason all my apps crash one by one. (Assume its the lack of sd-ext on my card... ill do it tonight).
Before I flash it again, can you reccomend any other good ones?
I don't use YouTube.
I text and use the web browser a lot.
I need wifi to work, but wifi hotspot is more important.
Ics seemed to have better battery life and less tws , so I'm hoping other ics will too.
I like launcherpro and the tmo theme Chooser, so that would be a plus too.
Overclocking seems to break my phone, no matter the rom, so maybe take that into account.
Thanks..
Also, how big should the sdext be? Gu
Thanks..
