03-08-2013 02:16 PM
26 12
tools
  1. 121jose's Avatar
    hello, I rooted my Lg Optimus V with Gigerbreak everything was good until I tried to factory reset it. my phone will only go into clockwork mod recovery 5.0.2.7 which I didn't know I had. I'm aware that to select sonething I'd the camera button but it won't let me. when i try to select something thee text flashes but that's it nothing else happens. please help yes I am a noob.
    03-02-2013 08:34 AM
  2. WarriorWithWood's Avatar
    I'm betting you tried to factory reset from the settings menu instead of the recovery console.
    03-02-2013 09:03 AM
  3. 121jose's Avatar
    yes I did.
    03-02-2013 09:07 AM
  4. yaconsult's Avatar
    03-02-2013 11:03 AM
  5. sellers86's Avatar
    Read before you do stuff like this. Follow that links directions to a letter.
    Sent from my Evo V 4G using Android Central Forums
    03-02-2013 11:11 AM
  6. 121jose's Avatar
    alright thanks ill try this.
    03-02-2013 12:13 PM
  7. Chillidog66's Avatar
    I hope you can fix it, best if luck.
    Sent from my Galaxy s3 using Android Central Forums
    03-02-2013 12:58 PM
  8. 121jose's Avatar
    how long is it supposed to be taking?
    03-02-2013 01:28 PM
  9. bjzapp's Avatar
    D kids.......:roll:
    be patient and follow the steps properly...write them down even!
    really?!
    03-02-2013 02:13 PM
  10. 121jose's Avatar
    okay so I tried the guide and I had no luck.
    03-02-2013 03:11 PM
  11. sellers86's Avatar
    Your going to need to go into more detail than that before anyone can help you.
    bjzapp likes this.
    03-03-2013 02:07 AM
  12. thewraith420's Avatar
    Hmm.. If you didn't know you had cwm... Did you by chance use rom manager? You probably have an incompatible recovery. I'm pretty sure there's ways to fix this without kdz. Ever setup adb?
    Tapatalk'n it from my VM670 running OM-Mandylion on LS670ZVJ firmware
    03-03-2013 08:05 PM
  13. sellers86's Avatar
    That recovery is gone from rom manager. Remember? Lol
    Sent from my PG86100 using Android Central Forums
    03-04-2013 05:34 PM
  14. thewraith420's Avatar
    The one for the v is gone that's true but the optimus c is still there and someone who doesn't know better could easily end up flashing it
    03-04-2013 07:19 PM
  15. sellers86's Avatar
    Does the optimus c recovery even pop up on the list for the OV?
    03-04-2013 07:45 PM
  16. AndyOpie150's Avatar
    Yes unfortunately. And I've helped someone already who has flashed it. Borked their phone but good, it did.
    03-04-2013 08:44 PM
  17. thewraith420's Avatar
    If that's what the op did my idea is to use qtadb to hopefully flash a new recovery
    A-android-B likes this.
    03-05-2013 12:10 AM
  18. AndyOpie150's Avatar
    Its possible but the class path to the Java jdk6 java.exe must be set properly, as well as the path to the adb.exe.
    The OP hasn't posted a reply in some time now though.
    03-05-2013 05:23 PM
  19. upconvert's Avatar
    And yet here we sit, waiting to help.
    03-05-2013 08:48 PM
  20. AndyOpie150's Avatar
    Twiddle thumbs, yawn, fall asleep.
    03-05-2013 09:55 PM
  21. skurtov's Avatar
    Could he flash a new recovery through flashboot and adb?
    Sent from my A500 using Tapatalk HD
    03-08-2013 10:58 AM
  22. thewraith420's Avatar
    I know there's a way but I don't know the commands with adb. I actually have flashed a recovery from recovery via adb before but I just copied the lines from something I read.
    03-08-2013 11:15 AM
  23. AndyOpie150's Avatar
    If you can still access the recovery, you just need to flash the Cannibal Open Touch recovery.zip from the current recovery. Then go to the advanced section of current recovery.
    Choose to reboot recovery, which will boot into the COT recovery.
    Then find the "fix recovery loop" option.
    That should fix you right up.
    03-08-2013 01:44 PM
  24. AndyOpie150's Avatar
    If that doesn't work then we'll try fastboot commands to "flash erase all", then push and flash new recovery.
    03-08-2013 02:05 PM
  25. thewraith420's Avatar
    Problem there is in the op he said he couldn't select anything.
    Lol feels weird trying to fix the ops problem when it seems he's not around anymore... Oh well at least it'll probably help someone else thru Time
    upconvert likes this.
    03-08-2013 02:11 PM
26 12
  1. my firmware didn't upgrade to 1.6. please help
    By travpadg912 in forum T-Mobile myTouch 3G
    Last Post: 07-10-2010, 11:37 PM
  2. Please help me!!! =(
    By yojosefo#AC in forum T-Mobile G1
    Last Post: 01-18-2010, 12:40 AM
  3. Please help me!!! =(
    By yojosefo in forum General Help and How To
    Last Post: 10-12-2009, 10:31 AM
  4. SOS: All G1, Gmail, Gtalk contacts disappeared. Please help!
    By android007 in forum General Help and How To
    Last Post: 03-17-2009, 05:28 PM
  5. SOS: Please Help: IMport SMS from XML file to G1
    Last Post: 02-06-2009, 12:15 PM
