1. chcub1's Avatar
    Im sorry to be making a thread out of this, but its my only phone ans i need badly. Ok earlier i made a 2gb ext from my 8gb sd card, i flashed pac rom from the kraven and flashed a INT2EXT from xda ill post a link and it took me like a million tries to get it to work everytime i tried the phone got really laggy and then froze i pulled the battery and when it booted up it was at the welcome screen so i flashed the rom again and it did the same thing happened but now it seemed like it was going to work but i couldnt download apps it said error 491 and solutions were to wipe dalvik cache so i did and my phone is stillbooting up an hour later
    Sent from my VM670 using Android Central Forums
    03-03-2013 08:48 PM
  2. upconvert's Avatar
    Maybe you should try a more tested ROM. There are several GB ROMs like mirage or bobzhome, or theKraven's cm7 that don't require the trouble shooting that an alpha stage ROM like the pac ROM will.
    You can use the app link2sd from the play store to take advantage of that sd-ext partition, and with a jb theme and the holo launcher and holo locker, any of those cm7 variants will look and feel a lot like jb.
    Sent from my GT-P7310 using Android Central Forums
    03-03-2013 09:32 PM
  3. AndyOpie150's Avatar
    1. You can only use 20% of the actual usable space on the SD card for the partition.
    2. SD ext apps and scripts need a 1-2 GB partition, with 2GB being optimal.
    3. Most Gingerbread, ICS, and Jellybean ROMs for our phones use the ext.4 format. The others work with ext.3
    If you have an 8GB SD card your partition should be no bigger than 1.5GB
    If you used the ext.3 format and it didn't work you need to try the ext.4 format or vice-a-versa
    Mini Tool Partition Wizard can change the format of the partition easily.
    Download BootIt. It will fix any mistakes you make to the SD card when trying to format should they happen.
    Note: Never use the erase/wipe option in Mini Tool or Utilities like it. It will Bork the SD card, then you will need to use BootIt for sure.
    03-03-2013 10:50 PM
  4. _alexkta's Avatar
    I think Zen garden can change the partition too
    Sent from my VM670 using Tapatalk 2
    03-03-2013 11:26 PM
  5. AndyOpie150's Avatar
    Hmm! I'll have to dig thru the settings. Very interesting info indeed.
    Edit: Sure enough. Thanks for info _alexkta.
    Advanced section/Utilities/Partition Manager/Convert Partition. Options to convert to ext.3 or ext.4
    Cool! I liiike It.
    Learn something new everyday.
    03-04-2013 07:39 AM
  1. HELP! Need to get G1 Working or Dieter Will Kill Me!
    By Rene Ritchie in forum The Android Central Lounge
    Last Post: 06-02-2013, 04:17 PM
  2. My Turn - Help Dieter with the G1
    By Dieter Bohn in forum The Android Central Lounge
    Last Post: 04-26-2013, 08:08 AM
  3. Round Robin: Help Jennifer with the G1!
    By Jennifer Chappell#CB in forum The Android Central Lounge
    Last Post: 12-14-2009, 09:59 PM
  4. SOS: All G1, Gmail, Gtalk contacts disappeared. Please help!
    By android007 in forum General Help and How To
    Last Post: 03-17-2009, 05:28 PM
  5. SOS: Please Help: IMport SMS from XML file to G1
    Last Post: 02-06-2009, 12:15 PM
