1. sean_nice16's Avatar
    i downloaded button remapper but i dont understand how to work it
    03-16-2013 04:52 PM
  2. thewraith420's Avatar
    Download es file explorer
    open it
    Hit menu and go into settings
    I can't remember the exact layout but you need to enable root privileges and mount /system as writable
    Browse to /system/usr/keylayout
    Edit qwerty.kl and thunderc_keypad.kl
    Keys 139 and 102 are the important ones
    Also what rom are you trying?
    Tapatalk'n it PAC-Rom style! Android 4.2.2 on my VM670 running LS670ZVJ firmware
    03-17-2013 12:32 AM
  3. AndyOpie150's Avatar
    +1 ^
    Except for the root file manager.
    Root Browser lite is the best free root file manager.
    Root explorer is the best root file manager, but it's a paid app.
    03-17-2013 08:27 AM
  4. thewraith420's Avatar
    +1 ^
    I'll have to try it out some time.. I've just only used es and didn't know if root browser lite could edit the files
    03-17-2013 02:03 PM
  5. AndyOpie150's Avatar
    I was of the same opinion my self just last month. 50 year old brain can't remember who mentioned it, but I ended up downloading and checking it out. Blew ES File explorer out of the water.
    Does more, doesn't require much in the way of setting it up, etc.
    I use Root Explorer, but recommend Root Browser Lite to all new rooted members and those who can't afford to buy apps.
    03-17-2013 08:11 PM
  1. Replies: 3
    Last Post: 08-04-2012, 05:36 PM
  2. The Hardware Button
    By mazzmoney95 in forum Samsung Galaxy S3
    Last Post: 07-17-2012, 09:43 PM
  3. Replies: 5
    Last Post: 10-04-2011, 09:03 PM
  4. Optimus V roms on the S
    By lgos in forum LG Optimus S
    Last Post: 09-21-2011, 01:13 AM
  5. Replies: 0
    Last Post: 06-10-2010, 11:04 AM
