Gapps / Camera Workaround for BobZhome CM10
itzpremix
88
Dev work isn't really that easy. To flash Pac-rom you need to flash the my in the right order. If you flashed the virgin fix first it won't help anything.
1. Flash the rom
2. Flash gapps
3. Flash virgin fix
4. Flash cronmod's int2ext patch
Without int2ext it won't have enough room for apps. do you have an ext partition?
Tapatalk'n it PAC-Rom style! Android 4.2.2 on my VM670 running LS670ZVJ firmware
Okay I didn't say dev work was easy. I'm a nerd. I learn quickly and efficiently. It might be easy for me I mean most super high tech stuff is for me. I outsmarted nearly all tech support operators that I've ever communicated with.
Anyway I don't see how nobody else installs this. Let me explain very clearly. Installing the rom first will not work because the build.prop file clearly states that the rom is for ls670 not vm670. It aborts the installation.
And yes I have sd-ext. I use mounts2sd first (after downloading busybox for a "just in case") to configure busybox settings and create an init.d script, reboot, load up Link2SD and select my ext type, reboot, then link everything that I can using Link2SD. I know how to properly utilize Titanium Backup Pro along side Link2SD. Just have to restore in segments.
So yeah. How can I install the rom first if build.prop stops me? Good luck.
thewraith420
1,987
223
63
It's your recovery stopping you most newer ones allow ls670 asserts cwm green does not I posted a link to a fix in kravens thread in reply to your post there. Of course using a different recovery would also be a workable fix
itzpremix
88
Hmm. I still have the recovery from the sticky post I got my daily rom from (reference first post). Could I use that recovery instead?
thewraith420
1,987
223
63
Note: after flashing the new recovery you should make a backup with it prior to trying any new roms
itzpremix
88
ERMERGERD I love it! Keeping this recovery.
Since I'm already using Link2SD in a way that I'm used to, do I really need the int2ext script by cro--whatever his name was? I'm a bit confused on what to do with it anyway, I downloaded it just in case. *waits for response*
thewraith420
1,987
223
63
I don't think link2sd will work with pac rom but so long as you have a backup there's no reason you can't try
itzpremix
88
Right. Okay so fixing to flash things in this order:
ROM zip
Gapps zip
Virgin Fix zip
Cronmod's script zip
Report back shortly, brb.
itzpremix
88
Don't forget to wipe....... Lol
Ha of course I wipe. Everything was magical and great until installing the cronmod's script. It said cannot copy update-binary. Then aborted. What now?
itzpremix
88
Make sure you have the right one int2ext
http://forums.androidcentral.com/showthread.php?p=2608606
Got the rom booted up. It's slow :/ like a bit too slow... And verdict is...
Doesn't charge. Damnit. I know my phone charges while in recovery and thanks to the new recovery I can see battery stats. But eh. That means I'd have to charge it every 4 hours because of my high usage. I live on this phone. Back to my backup now. Figuring out what to do.
_alexkta
289
Since you think its the gapps affecting it just try flashing the rom to see if it charges without them
Sent from my VM670 using Tapatalk 2
thewraith420
1,987
223
63
I've got no answer for the not charging but i do know the speed of the rom gets better after a few reboots plus some time to settle in
thewraith420
1,987
223
63
Something to try..... Find some of the flashable kernels for the ov and try flashing them to pac or another 4.0+ rom you want to try. I can't guarantee they'll boot it because most are built for gingerbread but if it did boot it'd be interesting to see if it charges then. I'd probably see if the Mandylion kernel will work
itzpremix
88
Regarding kernels... I'm a complete dvmb@ss lol. *research time*
fallingOutOfLoveWfithTech
