1. Redchigh's Avatar
    So, running PAC ROM (jellybean 4.2), and everything is smooth as silk after flashing everything plus crossbreeder, except int2sd isn't working. (What does "comparable with swap2int" mean?)
    Another problem, is I think I should be using ext4 for my sdext. How do i kbow what format Im using? How do I reformat my sdext? (I know ill have to reflash.)
    I think i might need a new recovery... I'm running cwm 3, but i don't have adb (On PPC Mac os X).
    Is there an easier way to flash a recovery?
    05-09-2013 12:28 PM
  2. _alexkta's Avatar
    Just flash zengarden recovery through your current recovery
    Sent from my VM670 using Tapatalk 2
    05-09-2013 03:04 PM
  3. Redchigh's Avatar
    Didn't know that would work. Thanks.
    05-09-2013 03:39 PM
  4. AndyOpie150's Avatar
    When you flash a new recovery thru a recovery the new recovery must be zipped. You don't need to wipe anything, just flash like a ROM or theme.
    Then go to the advanced option in the old recovery and choose the reboot recovery option. It will now boot into the recovery that was flashed.
    To flash a recovery from a termimal emulator make sure it's unzipped (Will have .img on the end if unzipped), then type in:
    Code:
    flash_image recovery /sdcard/(name of recovery exactly how it's spelled out on the sd card)
    You should get a # after typing that all in (You might even get a stream of almost identical looking code just prior to the #).
    05-10-2013 04:21 AM
  1. ARCHIVED: Problem after installing custom recovery
    By chanoaji in forum Epic 4G Touch Archived ROM's and Hacks
    Last Post: 05-28-2013, 12:16 AM
  2. Problem after installing custom recovery
    By chanoaji in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 05-02-2013, 10:08 AM
  3. [Guide] How to install a custom recovery and rom
    By Takenover83 in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 10-03-2012, 08:02 PM
  4. Help with custom recovery and rom!
    By wade70592 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 05-10-2011, 10:31 PM
  5. Custom Recovery and Root
    By jeffreynothing43 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 02-02-2011, 11:35 AM
