I have an Optimus V.
Several months ago I rooted it. I followed the instructions here exactly, but to be honest I don't really understand what I did. I did it for the reason most people do... my internal memory was full and it was the only way I could use my external SD card for storing apps, with Link2SD, etc. It's been working fine.
Until now.
the issue is I need to call Virgin Mobile because the cell tower in my town has been down for several days since we had a severe lightning storm. The last time I called them, they wanted to test my phone by putting some codes in. The codes didn't work and I found out after that it was because I rooted my phone and have a different ROM than they put on there.
Now I really need to call them again. But I need to go back to a different ROM that will enable those codes to work when I call them.
I have searched and I can find instructions for rooting and flashing a ROM from the beginning, but not the instructions I need -- how to flash a ROM after i'm already rooted, and also which ROM I should use that would enable me to call in and have those codes work.
I **********really************* would appreciate some help on this. Keep in mind, I'm technically minded but I don't understand rooting and flashing. I might need someone to help me through, step by step.
Thanks
gary in Vermont
Until now.
Thanks
gary in Vermont
