Hi everybody! The folks on this forum were so helpful to me when I wanted to take my stock OpV, root it & install gingerbread. It was surprisingly easy, and I did it to 3 phones. At the time, there wasn't a working ICS rom but now there is! I'm thinking about going to the quattrimus ics rom, and I've got a few questions. (since there's not a step by step ***** proof guide that I can find, like there is with gingerbreak.)
1.) My current rom is the one that the step by step guide talked about: CGM 7.2.0 backside IHO. I went from stock to this, now how do I go from one rom to another?
2.) Rumor has it that quattrimus has issues with 2SD type apps...what about regular old App2SD? I've used it for, well, forever it seems and I'd really like to keep it if I can.
3.) I also read somewhere about how folks were able to make a partition & increase their internal memory to some insane amount & have a ton of apps with out worrying about running out of room. Seems to me that even though I have tons of room on my SD card, and nearly all my apps are on said sd card, I still end up cutting it close on internal memory & having to uninstall less important apps. (I guess even though something's on the sd, it still has "fragments" on internal???) Ok, so how does one go about doing this partition?
Any tips, tricks, how-tos, warnings & recommendations would be mucho appreciated!
