09-16-2012 11:44 PM
48 12
tools
  1. colonelcack's Avatar
    As a rule of thumb the partition size should be no bigger then 10% for a Class 10 and for a class 2 no bigger then 5%. An sd-card is flash memory, and flash memory does not take partitioning very well if the partition size is to great. Another rule of thumb is to use either ext3 or ext4 because both file systems use journaling, which means that if you have to pull the battery out the data on the ext partition well not be lost.
    There are some scripts in many custom ROMS that move the data over the the sd-ext partition like the one used in my ROM, and by doing so it acts like internal storage. What the means is what ever your sd-ext partition size is shows up as your phones internal storage.
    I bought a 32GB class 4 card. What should my ext partition be? And i'm running backside iho but soon want to upgrade to quattrimus when beta is announced...
    04-07-2012 03:49 PM
  2. EarthnFire78's Avatar
    For a Class 4 I would use the Class 2 rule of thumb for the partition size, and make the partition file system and ext4
    You would be looking at a 1.15GB ext4 partition in your case.
    04-07-2012 04:00 PM
  3. tvall's Avatar
    On a class 2 or 4 I would personally recommend ext2. The journal would decrease performance and life span of the card.
    04-07-2012 04:19 PM
  4. EarthnFire78's Avatar
    That is even true for a Class 10, that is one of the reasons a lot of scripts that move data of the ext also adjust Read-Ahead-Cache.
    04-07-2012 04:42 PM
  5. droidmyme's Avatar
    Can someone knowledgable explain why Link2SD is used here? I simply use Android's native "Manage Applications," select the app, and click "Move to SD card." It does the exact same thing and doesn't need an app. This method frees up the same amt of internal space as L2SD.
    If the app I'm using doesn't have storage permissions, I simply find one that does. That's the great thing about Android market: a variety of apps.
    The only noticeable difference between FAT32 and ext2 is journaling. Really the two file systems are not going to have any speed differences in Android apps.
    My understanding of Android is that you don't see performance hits until you drop below 20MB of internal space. Freeing up to 140MB of space isn't really going to do anything more than 40MB of internal space. People should explain this useability aspect from the get-go right? So again, why make things complicated? Why not just use manage apps?
    04-09-2012 11:25 AM
  6. EarthnFire78's Avatar
    Linkt2SD is much more then an app manager, what it does is mount the second partition as phone internal. So now you can move all you apps and widgets to the sd partition.
    Point of fact neither FAT32 or ext2 has journaling.
    04-09-2012 12:32 PM
  7. droidmyme's Avatar
    Ok, that's pretty cool. Meaning, all your system apps can run off the SD as well?
    So ext4 has journaling but not ext2 right?
    04-09-2012 01:24 PM
  8. EarthnFire78's Avatar
    Would not run any system apps off the sdcard, as stated earlier in the thread flash memory does not like being partitioned to a great degree: and well shortens the life of the sdcard, Journaling a great thing, if you every have to pull the battery the data on the card would not be effected.
    04-09-2012 03:10 PM
  9. droidmyme's Avatar
    You say that Link2SD moves one's apps and widgets to the SDcard. Which is exactly what App Manager does. So I don't really understand how these two things are different.
    04-09-2012 04:24 PM
  10. EarthnFire78's Avatar
    Read the info about Link2SD, I personally do not use it, I use a script that marks the sd-ext partition of my sdcard as internal storage. There is a difference with Androids app Manager and anything that uses the second partition for apps. The mean difference is that app and widgets that you have on your sdcard moved over by Android, are not functional when the sd is mounted to your computer: now if those same apps are on the sd-ext partition they can still be used while the sd is mounted to your computer.
    droidmyme likes this.
    04-09-2012 05:38 PM
  11. droidmyme's Avatar
    Ahhh, that is super helpful. Thank you! So when you say "second partition," that is sd-ext.
    What script is it that you use? What folder does it go in, and does it have any dependencies?
    04-09-2012 05:50 PM
  12. harriett_watt's Avatar
    Hello all,
    I would like to try this, as I am sick of the low storage messages, however I am relatively new at modifying my phone and am nervous about doing something wrong. So I was hoping some kind soul could clarify a few points for me, and I apologize if some of my questions are too basic.
    1. The backup app recommended here is titanium; I am using MyBackup Root. Is that ok or should I switch?
    2. My phone is rooted but I still have the stock ROM. I did install a custom recovery image using Flash Image GUI (I followed the instructions on this page: http://forums.androidcentral.com/opt...ustom-rom.html). Will that work for this?
    3. I have an 8GB SD card, but I'm not sure what class it is. There's a little 4 in a circle on it, is that it? And if it is a class 4, so I still follow these steps or do something different?
    Those were my main questions, and I appreciate any help you guys can provide. Thanks!
    07-24-2012 08:45 PM
  13. clodfelterac's Avatar
    1. should be fine...
    2. yes...
    3. same steps...
    remember to make a copy of your sdcard contents to your pc, before doing anything...
    07-24-2012 09:01 PM
  14. riggerman's Avatar
    If you are still on the stock rom and kernel, your second partition (for link2sd) will have to be formatted to FAT32, the stock kernel does not support anything else. You will have partition your sd card with Mini Tool Partition Wizard on your PC. The recovery will format it to ext3, which the stock kernel can't read.
    07-25-2012 01:37 AM
  15. harriett_watt's Avatar
    Hi riggerman,
    Thanks for letting me know that. So I would have to download Mini Tool Partition Wizard, plug the SD card into my computer, and partition that way? Will this be pretty easy to figure out or are there instructions somewhere? I assume with this I won't have to boot the phone to custom recovery, but all the other steps stay the same? Also, it was mentioned that FAT32 does not have journaling, will that be a problem? Thanks for all your help!
    07-25-2012 09:00 PM
  16. terthii's Avatar
    Can someone explain to me why I would do this instead of force moving all my apps to the SD card with Titanium Backup?
    07-26-2012 12:27 PM
  17. harriett_watt's Avatar
    Hi all,
    I've been working on this some more, and have decided to flash a custom ROM as I can't seem to get the Mini Partition Tool to work for me. Anyway, what would you recommend for a ROM which is stable and supports ext3? Thanks again!
    07-28-2012 08:44 PM
  18. harriett_watt's Avatar
    Ok never mind, I finally got this to work. I used some of the tips from mngl1500's post earlier in this thread, thank you mngl1500. I partitioned my SD card on the phone as described here, and then used EaseUS Partition Master on my computer to change the partition from ext3 to FAT32, and then it worked! I linked all apps possible to the new partition and I now have 178 Mb total internal storage (I made the partition smaller because my SD card is class 4 and I went by the 5% rule recommended here). Thank you all!
    07-29-2012 12:21 PM
  19. d8sychain's Avatar
    I know this is a little old, but I was just reading through this thread and would like to add a little more clarification to this.
    Link2SD helps with space so much more than App Manager because it has the ability to move all data, including the application file, the dalvik-cache file, and the library files for the app to the sd-ext section (a sd partition). (BTW, Partitioning is dividing a physical storage space in to different logical storage spaces) It moves all of the app data from it's original location to the sd-ext and then creates links in place of the original location to that data so that it is all connected back to the internal location and continues to function. Link2SD also has the ability to move apps that can't normally be moved and automatically move apps to the SD as they are downloaded and installed, saving you time and space so you can keep spending hours in the Play Store clicking install app after app (Ooo I want that one, oh and that, and yeah this one here, ect...)
    App Manager on the other hand leaves data behind. Depending on the application, that can leave a bit behind and still take up a bit of your internal storage memory after quiet a few apps. Also it can't move certain apps. Another thing, apps are moved to the User's Fat32 section, which when turning on Mass Storage on your device, unmounts that logical section of space (the space other than sd-ext unless your card isn't partitioned then it's all the space) and mounts it on the computer, making that space and content unavailable to the device
    Take the app Netflix for example. With all of it on my internal memory the total storage is 26.96MB. Now if use App Manager and click Move to SD I get 1.21 MB left behind. Another example is Google Maps, 19.82 MB. App Manager won't let you move it to the SD card but Link2SD will let you move any app. Saving you room for apps that you do want on internal memory.
    I hope that this helps explain so differences and helps new comers to the scene
    This is my knowledge and understanding of this, If I am incorrect in any way please feel free to correct me, as knowledge is useless if it is incorrect.
    09-03-2012 08:18 PM
  20. Shinkenred's Avatar
    Using these steps on an Optimus S with Xionia Recovery, the partition was successful (1GB on a 16GB card), but, because the ROM wouldn't boot, the computer I was on ran out of time and shut down...you can guess what that means: I LOST EVERYTHING. PERIOD. Never had a chance to copy it back to my memory card because the damn phone wouldn't boot up. NOT A HAPPY CAMPER ABOUT THAT ONE, FOLKS.
    UPDATE 2012Sep12 Okay...unbricked my Optimus S and got her running. But Link2SD won't work: I keep getting these errors. The first is along the lines of "ext2 may not be supported" and "try FAT32". Trying that brings the other error: "device or resource busy."
    In a nutshell...it won't function as it should. What to do?
    09-10-2012 08:54 PM
  21. sugarbabe33093's Avatar
    I did the backup and copied ALL the files to my PC, put the 32gb sd card in, partitioned it, mounted it, copied all the files back, but I have no idea where they are and nothing is right on my phone!
    I can't even reinstall Titanium Backup on my phone now; it keeps saying there is insufficient space on the device. When I plug it in to my PC it says there are 27.5gb free of 27.7 or close to that.
    What did I do wrong/what do I do now?
    09-10-2012 11:23 PM
  22. d8sychain's Avatar
    Try choosing ext4
    09-14-2012 02:51 PM
  23. sugarbabe33093's Avatar
    When I try to partition my sd card, it doesn't give me the option to increase the size of/use my ext4.
    09-16-2012 11:44 PM
48 12
Tags for this Thread
