The port over to the Optimus V of these kernels was 99% the work of LeslieAnn. She should get all the praise. I guess zefie should get some credit seeing as how he created the kernels, debugged them, and put them online. Here is the original Optimus S thread for reference: http://forum.androidcentral.com/lg-...9-oc-kernel-xionia-kernel-2-6-32-33-v013.html
Here are the kernels ported over for use with the Optimus V:
xionia_kernel_005_bootimg_OptimusV_signed.zip (from Rodimus)
xionia_kernel_008_bootimg_OptimusV_signed.zip
xionia_kernel_009_bootimg_OptimusV_signed.zip
xionia_kernel_010_bootimg_OptimusV_signed.zip (updated 4/13/2011)(use anykernel version for CM7)
xionia_kernel_010_anykernel_OptimusV_signed.zip (updated 4/13/2011)(reload your backup and use this if you have issues with the bootimg version)(Works great on this S rom)
xionia_kernel_011_bootimg_OptimusV_signed.zip
xionia_kernel_012_bootimg_OptimusV_signed.zip
xionia_kernel_013_bootimg_OptimusV_signed.zip (use anykernel version for CM7)
xionia_kernel_013_anykernel_OptimusV_signed.zip (reload your backup and use this if you have issues with the bootimg version)
xionia_kernel_014_bootimg_OptimusV_signed.zip (4/13/2011)(taken from Zefie's Scott Pilgrim rom)(use anykernel version for CM7)
xionia_kernel_014_anykernel_OptimusV_signed.zip (4/13/2011)(reload your backup and use this if you have issues with the bootimg version)
Bonus! This is the kernel from the aospCMod rom in flash-able form:
aospCMod_kernel_OptimusV_signed.zip
Installation instructions:
These have not been thoroughly tested yet. You must have a nandroid backup if you ever want to uninstall them. You can flash from one kernel to the other with no ill effects (with the exception of the anykernel version of 013, only install that over your original rom). They should also work with the Optimus S roms that already use a Xionia Kernel. Install the S rom, and then install the modified kernel on top before rebooting. The bootimg kernels will remove the Sprint boot animation and hopefully remove all incompatibilities besides the home-menu key swap. The anykernel version will work on the S roms too, but the Sprint boot animation will stay.
Report bugs here, but I can't promise that we can fix them.
Please report your success stories as well. We want to know which Roms these kernels will work with. Don't forget to write which Rom you are using and which kernel you installed.
010 seems the be the most recent kernel that doesn't have the USB mass storage bug. Read here for the change log.
Known issues:
- Install the rom of your choice.
- Make a nandroid backup.
- Install the kernel on top using your recovery or Romtools.
Known issues:
- 014,013,012,011 - "Turn on USB storage" never confirms that the mode has been enabled (even though it has been enabled and you can access your card from your computer). As a result, you must go to Settings -> SD Card & Phone Storage -> Mount, to turn USB storage mode off and get your card mounted again.
- 010,013,&014 anykernel - Swaps the Home and Menu keys when used with aospCMod rom. Switch them back using a button remapper app or editing the keyboard file located in: /system/usr/keylayout/ or try flashing this.
- all bootimg - They do not work with CM7 (aosp & zefie's). Use the Anykernel version instead.
