1. Zeldster's Avatar
    HELP!
    When i put in the
    chmod 4755 su
    it said Unable to chmod su :No such file or directory
    when I was using the stickied thread to root my Optimus V.
    It said the same thing for the next command after that.
    I still went on though, and i installed titanium backup, it said it's not rooted..
    Im pretty sure everything else went right..
    I was using the latest version of Super One Click.. 1.8
    04-17-2011 09:41 AM
  2. Zeldster's Avatar
    Ok so now I got the similar command with busybox working by making the platform-tools folder and the c:\android folder not read only.. and su doesnt have read only checked either, so idk why its not working..
    04-17-2011 09:54 AM
  3. DroidXcon's Avatar
    could be a number of things, perhaps superoneclick did not successfully temp root.
    or the files did not push because they are missing from the folder.
    if you are having more trouble we can screen share and i could help you out with this
    04-17-2011 10:01 AM
  4. whyaphoenix's Avatar
    delete
    04-17-2011 03:30 PM
  5. Zeldster's Avatar
    I got it working after redoing it some times..
    How do I flash aospcmod on the Optimus V?
    Can anyone help?
    04-17-2011 04:29 PM
  6. RavenSEAL's Avatar
    Can anyone help?
    Did you flash the recovery?
    04-17-2011 05:11 PM
  7. Zeldster's Avatar
    What does that mean? And how do you do that..? And what is it for?
    (This just shows how much I don't know about this)..
    But I see that you have aospcmod, could you help me out? I used the method in the sticky to root my Optimus V
    04-19-2011 06:39 PM
  8. mmarz's Avatar
    04-19-2011 06:53 PM
  9. Zeldster's Avatar
    TYVM
    I'll try it out
    04-20-2011 08:06 PM
Tags for this Thread
