droidmyme
Ttt
Hey guys,
Bumping this. I have an OV I need reverted to 100% stock. I got the ROM stock by using Nandroid backup, but I was having problems flashing the stock recovery in terminal. So I tried using Jimmy's Flash Image GUI. It worked - sorta.
Now I have this setup: stock ROM, stock recovery flashed but not working 100%, root access, and busybox installed. Here's the issue I'm having: I open terminal and try to run PicaSticks method. First line works ok, but on the 2nd line I get "remount not found."
Ok, so I try the simplified method of JerryScript moving flash_image from /sdcard directly into /system/bin. When I run chmod 755 /system/bin/flash_image it returns "flash_image not found."
When I use a file manager to try and copy flash_image directly to /system/bin, it says "permission denied."
What gives? Are the Android gremlins cockblocking me here for no reason? Lol
Hey guys,
