Before you think your battery drain issues are with the ROM or kernel you are using, uninstall Skype and see how that works out for you.
Skype is known for absolutely murdering battery life, even if you sign out (or never sign in) and even after you kill the app and running service. It refuses to let go of the sensors and can drain up to 10% battery per hour. The only solution is to uninstall it completely.
For more info on how bad it really is, see here and here and here.
