I've been trying to do this for some time, but I've hit a wall. I want to take the Settings.apk from my current rom (which ever one it happens to be). Decompile it. Edit some entries. Then recompile and sign it, so that I can use it with said rom.
I've tried using apktool (and a few automated versions of it). It works great to decompile and recompile. I then use signapk.jar to sign the apk using a test key. But when I copy Settings.apk over to my /system/app folder, change the permissions, and reboot, the settings menu fails to load and my wallpaper disappears.
I thought that it might be edits I am making. So I tried decompiling, recompiling, and signing with no edits and I still get the same problem where the settings menu fails to load.
I even tried following this crazy guide: [HOW-TO] Modify the Keyboard and Screen Timeouts Settings
But I had the same problem.
I have successfully used apktool and my signing tool to edit and use other apk files. So I know that they work. Can anyone (probably a dev) explain what I'm doing wrong?
Thanks!
Update: Solution
Thanks!
Update: Solution
